12 point bolt heads - non-aerospace applications
T45
Curious to catalog some applications and favortite hex and drive sizes to tackle them 12 point fasteners.
These are general buckets I've seen so far, but pleae correct me as needed.
- Aerospace (various, may include spline, SAE+1/4 drive)
- Special application axel nuts (larger sizes metric 24mm+, 1/2 drive)
- Some engine hardware [...]
94EG8
Among what's already been mentioned Honda started using them on door hinges in the last few years.
Mhyde52
Averill Park, NY
The place I regularly run into 12 point bolts are the special pivot bolts on Toro reel mowers.
Only time I've specifically taken out a 12 point socket (3/8") in the last 6 months.
wafrederick
Holton,Mi
Jeep 4.0 headbolts,Harley Davidson engines with the rocker box bolts and the fastners holding the heads in place.3/8 12 point in the 4L80E
firworks
IL
I think Caterpillar uses them around in random places. I'm pretty sure I've seen them in a Motorgrader cab before.
wafrederick
Holton,Mi
Some axle nuts are a 12 point as well.Toyota/Lexus,Audi and VW use 12 point axle nuts.The Pontiac Vibe also which is a Toyota Matrix
Hondarancher4435
Old cat forklift wheel bolts. Dodge Ram driveshaft their all over the place if you don't have 12pt sockets you will want to get some
IsaacJ
Iowa
dana front axle unit bearing bolts, 9/16 I believe. Also 12mm for ford driveshaft bolts.
kunkernator
US of A
A lot of Caterpillar engines I work on use 12 point bolts, specifically in low clearance applications. Exhaust manifolds are common, as well as intake manifolds. Head bolts, rod bolts are almost universally 12 point.
mailpup
Los Angeles
If you ever go to a NASCAR race and visit a Chevy car and truck exhibit on the midway, they usually have a few high performance engines on standalone displays. Those engines have lots of 12 pt. fasteners on them.
alien
I changed all the engine and engine cover bolts on my last Harley to ARP Stainless grade 8-12 point fasteners. Better than the stock torx and allen bolts. And IMHO better than any of the chrome alternatives. Factory bolts always oxidized and the torx button heads would strip out. I never had a problem removing the 12 point fasteners. I am a fan.
I don't have that bike anymore and it would cost $500+ to do it to the new bike. I'm sure over time I will though.
T
T45
wow, lots of great replies ... thanks to all who contributed
RedF
Central Alberta
Driveshafts on all kinds of things, including medium duty trucks. Dodge unit bearings. Headers. Super handy for some styles of hydraulic orbit motors - nothing else fits well.
They are also known as "ferry head bolts". Why are you wondering?
