I'm thinking of getting either a 12 volt impact driver or cordless screwdriver. I think I will get either the Milwaukee 2450-22 or 2401-22 so the batteries will be compatible with the other Milwaukee tools I have.
I'm not sure which to get. I would mostly use it to drive screws into wood for projects around the house. I have a Sears 19.6 volt cordless drill that I use for that purpose now but its NiCd batteries are always run down when I want to use it. I also have problems with it being prone to strip out screw heads, which is probably my fault but irritating anyway.
I've been very happy with the battery life on my other Milwaukee Lithium battery tool and thought I'd get this. My goal is to get the tool that would be less likely to strip screw heads and would be likely to have some battery life when I want to use it.
I saw an infomercial yesterday for the Rockwell 3Rill which I guess I'd consider too since they are running a "free batteries for life" advertisement... although that sounds too good to be true.
Any suggestions as to which of these tools might be most appropriate?
Thanks
Thanks
