I was going to explain why they needed a relay but then I realized they really don't. Just wire the contacts in parallel across the remote switch. The switch has 12V on one contact but as long as the remote circuitry is isolated from the frame of the mower it will work fine.No need for a relay on a door opener switch. Open the switch up and just make it a momentary.
But both sides of the switch share an input. 12 Volts is needed across this input the activate the relay for the lights. Won't this same 12 Volts then flow from the switch into the Garage Door Remote? Isn't that a problem? (And the spelling error on the picture are not mine)No need for a relay on a door opener switch. Open the switch up and just make it a momentary.
And the switch is already a momentary, which is why I need the latching relay on the lighting branch.
Because the bottom half of the switch is being used to turn on and off lights. The latching relay is only on the light side of the circuit.What opener are you trying to interface this with?
If it needs 3 volts I'd wire in a voltage regulator.
I can't wrap my head around why it would need a latching relay on your momentary switch. GDO switches are typically a momentary signal/switch
The Yellow and Black wires are for lights inside the switch. And yes, my actual switch is Momentary. They make the switch in either mechanically latching or momentary. But both sides of the switch have to be the same. I went with the dual momentary because I already had the 12 volt latching relay and I didn't want to accidentally leave the GDO energized.Are you sure these switches are momentary? In the pic you posted the upper switch looks pushed in like the buttons lock in and on for the first push and off and out for a second push. Can you post a link to the data sheet or any info on the switch or a link to where you got it. Do you have a meter to measure the resistance between wires? If so you could verify if it is momentary or mechanically latching as I described. I did an image search and similar switches are for lights on vehicles and they should be latching for that.
It appears the switch is a simple mechanical switch but it has two voltage input wires and a ground which seems really strange. Maybe it has some circuitry inside? Really need more info but it probably came from China so maybe you didn't get any. You could check operation with a meter if you have one. Hard to give much help without knowing how the switch works.
The say the switch is "electronic" but I doubt there is any electronics inside - probably just contacts and lights. I'm guessing they say that to mean you can't power high power loads directly. It could be easily verified with a meter.The Yellow and Black wires are for lights inside the switch. And yes, my actual switch is Momentary. They make the switch in either mechanically latching or momentary. But both sides of the switch have to be the same. I went with the dual momentary because I already had the 12 volt latching relay and I didn't want to accidentally leave the GDO energized.
Custom Laser-Etched Dual Push Switches for Toyota
<span style="color: #000000;">Custom Laser-Etched Dual Push Switches for Toyota are perfect when you have limited space or wish to maximize your existing OEM switch locations, this dual switch doubles the number of switches you can install without the need to damage your vehicles dash by cutting...theswitchmasters.com
I have a self contained, circuit driven bistable latching relay already. I didn't need help with the light side of the circuit. Push bottom half of button, energize latching relay which energizes high amperage relay, lights on. Push bottom button again, de-energize latching relay which de-energizes high amperage relay, lights off. The latching relay is rated for 10 Amps, but my lights are rated at 15 Amps, so I need both relays.The say the switch is "electronic" but I doubt there is any electronics inside - probably just contacts and lights. I'm guessing they say that to mean you can't power high power loads directly. It could be easily verified with a meter.
For the lights a latching circuit is needed. You need to have a circuit that will latch the output on with one push and latch it off with another push. This is more than a basic latching relay that stays on with one input and needs a second contact to break a circuit to unlatch it. Google is your friend - use "spst momentary switch to latching relay" or similar. I don't see how you will do this with just multiple simple relays. Here's one solution that uses a dual coil relay. I
https://www.learningelectronics.net/circuits/momentary-switch-teamed-with-latching_03.html
It could be done with electronics also but I don't have a circuit handy.
This is getting beyond simple wiring diagrams and I usually get paid for this level of design...
Fair enough. That was not at all clear from your earlier posts. Yes, using a relay for the 3V remote is fine. There is no connection between coil and contacts in the relay so if you keep the connections separate there will be no 12V on the remote.I have a self contained, circuit driven bistable latching relay already. I didn't need help with the light side of the circuit. Push bottom half of button, energize latching relay which energizes high amperage relay, lights on. Push bottom button again, de-energize latching relay which de-energizes high amperage relay, lights off. The latching relay is rated for 10 Amps, but my lights are rated at 15 Amps, so I need both relays.
All I really needed to know was the fact that a standard 12 Volt automotive relay would work with a lower voltage on the switched side because I didn't want to send 12 volts through my 3 volt Garage Door Remote. Push button, energize relay, relay closes GDO remote microswitch, release button, de-energize relay, relay de-energizes GDO microswitch.
In the bottom half, I need both relays because the latching relay I have is rated for 10 amps and my lights are rated at 15. So I need the latching relay to activate the high power 40A relay else I'll melt the latching relay. And no, pushing the button energizes the latching relay. Pushing it again de-energizes the latching relay. So no need to flop polarity or really do anything other than send a 12V signal to the latching relays internal circuitry.I took some more time to think about the diagram some more and I think I understand a little more about what you're trying to do.
From what I see, the top half of the diagram is for the remote circuit, the bottom half of the diagram is for the lights.
1) In the bottom half - if the right hand relay is a latching relay, then why do you need the left hand relay? All you've done is repeated a 12V circuit that didn't need repeating. The 87/30 contacts on the right hand relay should go to 12V battery and the lights and you should be fine? (PS - are you required to invert the polarity to release the latch in your relay?)
2) In the top half - you don't need any voltage, you just need 87/30 contacts wired to the contacts of the remote circuit board. You just need it to make electrical contact (close the circuit) to mimic the remote's switch, assuming you're keeping the 3V battery that's on the remote's circuit board. If you're not and using a different 3V source and only wiring the downstream-side of the remote's switch, then ok, but that sounds like a really complicated way of doing it...
Great scott! 30 amps for lights! Switch to LED's man!!!In the bottom half, I need both relays because the latching relay I have is rated for 10 amps and my lights are rated at 15. So I need the latching relay to activate the high power 40A relay else I'll melt the latching relay. And no, pushing the button energizes the latching relay. Pushing it again de-energizes the latching relay. So no need to flop polarity or really do anything other than send a 12V signal to the latching relays internal circuitry.
And yes, in the top half I just need the relay to replicate the remotes microswitch, so I assume it needs to handle 3V because that is the power supplied by the remotes battery. My free schematic drawing software didn't have a way to sketch that out really.
And a Toyota Style switch is pretty standard.
