12" vs 18" Tiles
breeves2245
Initial research underway. Decided on tiles vs other flooring options, so got that done.
New construction 3 car garage 30'x36'. I'm thinking 12" tiles may give a busier look compared to 18". Don't care for the checkerboard design layouts, so the 12" has me thinking I need to avoid them if possible.
Selection on 18" seems to be very restricted and the pricing is much higher even when taking into account the reduced number of tiles needed.
Any advice? Just stick with the 12" and don't sweat it?
a91syncro
Stoughton, Wisconsin
12” tile will follow the floor if there are any imperfections. 18” you need a really flat floor to start with. I’ve been installing tile for 21 years now
mike93lx
Richmond, VA
Larger tiles will often have a bow up in the center, requiring back buttering. More work and more likely that you will have problems if you aren't very careful.
Firebrick43
West central Indiana
even 12" tiles should be back buttered imho. Although many pro's will not. Its insane how many pros will just put a four or five dots on the back and then the customer is wonders why their floor is cracking all the time.
mogandave
Bangkok
I saw a "pro" installing kitchen backsplash tiles with hot-glue.
mike93lx
Richmond, VA
The tiles should be checked and back buttered if necessary. If they are flat, i don't see any need if you are doing things right
Firebrick43
I suppose your right, I just do it as a matter of fact on 10"+ tiles and I have never had a tile crack, even once dropping a 2 lbs drilling hammer on one.
Spacep0d
Riverside County
Note on the 12" tiles...go with these if you don't absolutely need 18". Why? The affordable cutters are 13". For 18" cutters the price shoots up dramatically. You can still cut 18" tiles with a 13" cutter, as explained to me by RaceDeck. Just make a cut at your measurement line, rotate 180°, cut on the same line. Done.
I had to Google 'back buttering'. I think that's a good idea to do after all of the tiles are in-place. Then lift, butter, replace.
