1200 sq ft max garage options
deaton76
Good afternoon guys,
I have a unique situation where I'm building a shop and need to decide if I want to go with a 30x40 vs 26x46 or some variation in between. I am limited to 1200 sq ft on the bottom floor. But I will add a Mezz between 12-14 ft deep(shop will have 18ft walls). I can only have one garage door facing the street. This is going to be a multi purpose building(man-cave/sports, occasional work on cars.) It needs to be able to allow a decent area for my son to play basketball. The Mezz would host monthly poker games(16-20 players.) It will occasionally house a car and/or maybe a sxs. I plan on getting a 4 post lift that hopefully can be moveable under the loft to allow bball play. I wrench on cars periodically(change brakes, oil, etc... and might do a kit car down the road with my boys. It will also have a small bathroom in the back right corner. The biggest concern I have is the mezzanine being in the way. Which is why I'm considering a longer building but it requires I go narrower. Is there any gotcha's that I might not be thinking about? I've walked in a 25 ft open space and it seems pretty wide(wouldn't want it any more narrow) and I don't plan on parking a ton of cars in it(if at all, other than to work on one.) I would put most of my tools at the back, but might put some on the side, but I don't have a lot. I've determined I'm also going to put a lean-to shed behind it to house my garden stuff including a riding mower(don't tell the city, ;)). I've attached sort of the look I'm going for... Thanks!
Stuart in MN
Minneapolis
If you're limited on the footprint square footage, make sure there aren't also limitations on building height. 18 foot walls plus a roof means it will be pretty tall overall.
Yankeefarmer
Connecticut
Mine is 26 x48. I was limited to 26 ft deep by zoning and land topography. Overhead doors are in the 48 foot wall. My reg cab F250 8 ft bed fits okay, with room to work, but it’s tight. Every other vehicle has plenty of room. The benefit of having the longer dimension is that it provides room for a dedicated work space to one side, where my lathe, mill, and workbench live.
Will your one OH door be 16 ft wide?
D
deaton76
It can only be 12' wide by 14' high. I will have a smaller garage door somewhere along the long wall. Haven't decided on that yet.
Fixr
SW VA
Do you have the liquor license yet? I don't see a lift or toolboxes.
