CGT80
Has anyone ever run a 135 amp mig welder with 0.035" wire?
I will be fabricating some items out of 1/8" and 3/16" steel square tube and I need to use a wire that only comes in 0.035" and larger. There is a limited amount of 3/16" that I need to weld.
My mig is a miller 135 and I run 75/25 gas. I can lay great beads with this machine and 0.023" ER70S-6. I do not know if the larger diameter wire will be a problem with the limited output of this machine.
For the last project, I used my brother's miller 252. To run the correct wire in my machine I would have to spool some of it onto an 11 pound empty spool and probably go to a new gun liner and I think I would need a different drive roll for the feeder portion. He will likely be using his 252 for his own project at the same time, otherwise I would just borrow his.
It might be better for me to just cut all of my material, and maybe even tack weld it, so I can borrow his machine for a day or two to run my welds.
The 135 is a great little machine and I prefer it over the 252 for 1/8" and smaller work, but I have outgrown it's top end. My brother is not into welding as much as me, but he had the money and experience using my machine to go big when he decided to buy his own.
