120v to DC 24v LED lights. PIR sensor cause buzz
Toolfreaky
I changed to undercabiner lights to DC 24v with a DC24v dimmable controller, and also added a PIR sensor Everything works great but after adding the PIR, the PIR will buzz when I dim the lights. It does not buzz if no PIR is used or if not dimmed at the light switch. Light switch is also for LED dimming. Anyone have any solutions?
BTF-LIGHTING FCOB COB CCT Flexible High Density LED Strip 16.4FT 640LED/m Tunable 3000K-6000K CRI 90+ Dimmable LED Light Ribbon for Bedroom Kitchen Indoor Decoration DC24V(No Adapter or Controller) https://www.amazon.com/dp/B08Q3RKCZH?tag=atomicindus08-20
EMITEVER 50W Triac Dimmable Driver,Power Supply,AC 120V to DC 24V Transformer,Compatible with Lutron and Leviton Dimmers,for LED Lighting,Class 2,ETL Certified https://www.amazon.com/dp/B09ZL89LCY?tag=atomicindus08-20
3 Packs 12 V 24 V PIR Sensor Adjustable LED c Black Infrared Motion Detector Body Motion Sensing Light Switch PIR Controller with Embedded PIR Probes for Flexible LED Strip Lights https://www.amazon.com/dp/B09P3LK1B8?tag=atomicindus08-20
walta
Dutzow Missouri
Seems to me the PIR is not compatible with the dimmer.
You can pick one or the other or get an 120V PIR and place it before the dimmer and power supply.
Walta
