Walkers
I bought this 50 amp 12vdc power supply to run a 12vdc hose reel that I bought cheap. It is going to have 200’ of air hose on it, but will not likely be a daily use thing right now. So I wired it up using the existing switch on the 12 volt side to power the reel, and a cord and plug to power the unit with a/c, and it works as expected. Since this is not going to be a daily use thing I was curious as to how to power and switch it though. Should I bypass The existing 12 volt switch, and just switch the a/c side, or should I switch the a/c side and leave the 12 volt switch in the circuit?
