Hi folks. I have two questions.
1. I’m converting my on-board air compressor to a mobile unit and not sure how to wire up the 4 post relay and switch to power. Everything I found online talks about hard mounting the unit, but my plan is to run the power through jumper style cables and mounting it in a pelican case. Using the attached photo as an example do I connect wire one and two together as a single ground and then wire three and four together as a single power lead?
2. Can you use a 24 V circuit breaker fuse on a 12 V system? instead of using a 40 amp blade maxi fuse on my conversion I have a 50 amp resettable fuse that I’d like to use if I can but it’s 24VDC.
