14/2 for LED can lights?
mattlikesbikes
Austin TX
20amp circuits, but from the switch up to the actual can lights (6 4" per switch) can I just run 14/2? Up to the switch I have run 12/2.
I've got a bundle of 14/2 so trying to use it up. All the outlets on the same room circuit are on 12/2. These will be LED inserts into 4" cans. Also, planning to do retrofit cans, and just leave wire bundles in the attic. That way I can get the sheetrock up, throw a laser line up and get them all cut in with the hole saw, on the line. get back in the attic and make the connections.
Terry D
St. Louis, MO.
If you did that, you would have to change the breaker to 15 amps. For a 20 amp circuit, all the building wiring has to be #12
rlitman
Long Island
+1 Just go with 15A circuits for lighting. You'll be much happier using 14 wire in the can's boxes.
Quick240
Omaha, NE
Agree with everyone else. I wired my whole house and used 12 gauge for all outlets, and 14 for all lights. 14 is much easier to work with. I'm also pretty sure I could've put the whole house on one 15 amp lighting circuit (every light in the house is LED), but I split it up just for convenience sake.
