14" Cold Saw- SoCo full mitering, 100rpm, good shape
tarbellb
Oregon
Chico CA
Price
2500
SOLD SOLD SOLD
What: SoCo 14" (350mm) Cold Metal Saw 2spd (55rpm/100rpm)
Where: Chico Ca - (90 miles north of Sacramento)
Condition- Used, 100% functional, good shape
Price: $2500 obo
This is a industrial machine, designed for all day production use, giving dead nut accurate, burr free cuts every time.
Not to be confused with a "dry cut" saw that spins at 1500 rpm, this saw is 800+lbs, and spins at less then 100 rpm.
No hot chips, no dust, quiet, no deburring, super clean cuts down to 1/32" repeatedly, miters no problem, cool to the touch, saves tons of time.
Can be used to cut ANY METAL by simply switching out the blade. Huge cut capacity with a 14" blade (350mm).
Features:
_ 1989 SoCo 14" / 350mm Cold Saw for metal (stainless, carbon, aluminum, bronze, cast-iron, etc...)
_ 2hp / 3ph 16amp motor w/ phase-a-matic converter to run off 220v / 1ph (single phase) power
_ Mitering head for 60º left/right and even full parallel cuts/slitting.
_ Constant coolant flow w/ brand new pump and fully operation plumbing + extra coolant
_ Heavy duty self centering + dual sided clamping vise, nothing is moving around.
_ Cast iron construction, super heavy duty everything, including gear reduction box w/ oil fill line.
Includes-
_ Outfeed arm for long stock, swap to either side, includes stop block bar as well
_ Custom rolling cabinet, easy to move around, block when needed.
_ 3 blades total, 2 new or resharpened high quality blades for different materials! ($100+ ea)
_ 1 gallon of extra coolant
This is a excellent saw with tons of life left, only selling because im moving my business.
I have the blades, manuals, and the extras ready to go, wiring is ready to plug and play.
Will need to load yourself, has lift points, and rolls easily.
Check my other listing for excellent commercial / professional / industrial wood and metal machines plus materials
Look up "business moving 320"
planer jointer woodworking metalworking fabrication delta jet powermatic cabinets custom shop grizzly planner joiner usa made cast iron log diy woodshop dust collection rockwell unisaw uni saw table saw ts incra walker turner​
