Dennis93
I'm running exterior accent lights. 8 of them at 50w a piece = 400 watts. Divided by 110 volts = 3.23 amps. Now my upstairs is hooked up to a 15 amp circuit for all the lights. Should I just tap into that, or do I have to run a new wire and put a new breaker in?
I have room in my panel, just wondering if I need to go through all that trouble.
Also, if I use 12 gauge from what I learned I can go to a 20 amp breaker. However, none of the NEC charts I found tell me how far I can run a particular gauge of wire before it becomes too long and I need to go one gauge up. I'd run this from my garage to the main attic of my house, about 100 ft, plus add about another 100 ft for all the branches. Just wondering if any of you all had the luck of coming across the chart that tells you how far you can go before you have to get a lower gauge wire to get the same amps?
If I ran 12 gauge wire just for peace of mind, and then tapped into a 15 amp breaker, would I be doing any harm? Just wasting money? I ask because I only ran 14 gauge to my shed, and tapped it into a 15 amp, but when my well pump runs, that wire gets stupid hot, so wouldn't mind getting a lower gauge wire if it was less likely to get hot. But then I was thinking if I added thickness to the wire I would just be increasing resistance, and thereby making it hotter? I realize it sounds contrary to what is common, so tell me if my logic is flawed or not.
Thanks a lot!
Thanks a lot!
