$149.99 SafeRacks 4'x8' Overhead Garage Storage Rack
gte718p
A bit, but plywood would feel really constricting, not to mention darken the room a lot. Wire shelves leave the space feeling much more open.
Until you fill said wire shelve and no light passes anyway.
soob
Unless you're going to store a sheet of plywood on it, a lot of light will still pass through.
MasterOMayhem
I was looking at this and the space i have above my garage door when opened is 14 inches... i think i may order the longest hanging ones as i can cut the vertical bracket and have more length if i ever want to move it.
MrBreeze
Scottsdale, AZ
I picked up a pair of 4x8 safe racks from Woot.com for $139 each - while they aren't as strong as the Strong Rack's since the space above the garage door is limited (and thus I won't/can't be over-loading them) and I'm not sure how long we will be living here, I went with the more cost-effective option. (true, lumber and plywood might be cheaper)
Installed the first one today.
wizness
Houston TX
The storage racks are awesome. I don't remember what brand mine is but it's the same thing. You can see it hanging in the left corner. Nice to have stuff out of the way and looks better than plywood.
graffix000
Philly
All I see is the viper!! Nice!! :drool::drool:
MrBreeze
Scottsdale, AZ
Seems like a good deal for those not wanting to fabricate a shelf.
If you do want to fabricate one you can stop by your local farm supply store and buy a wire panel instead of plywood. http://www.tractorsupply.com/tsc/product/ok-brand-handy-panel-8-ft-l-x-50-in-h
I would still think you would need some additional bracing under these panels unless the loads are very light? Of course you could start with these panels, weld on some bar stock or rebar to strengthen....
For me, this choice of buy over build was worth the $140 to have everything delivered to my door and no time fabricating, painting, etc.
Mgnu
Valley of the Sun, AZ
I bought this same item from costco about 3 years ago. Honestly, it's not a super hot deal at all, it goes on sale for this "hot price" a minimum of twice a year, if not more frequently...
Still a good product. I did a few pullups on mine to test its' sturdiness. And I'm no pajama boy talking about Obamacare, I tip the scales around 220lbs. :lol_hitti
MrBreeze
Scottsdale, AZ
Ya, I figured the $139 I paid, or the $149 at Costco the OP paid was a good, but not some smokin' deal - that's one of the reasons I added to this older thread, rather than start a new one - just so others could see a common "sale" price.
wizness
Houston TX
FYI I got mine for homedepot for 129. This was it.
Performance 96 in. L x 48 in. W x 45 in. H Adjustable VersaRac Ceiling Storage Rack in Gray
navin
^for anyone using the VersaTrack..
The directions don't say it, but you can use the "drop brackets" as the mounting bracket into the ceiling if your ceiling joists aren't 12" apart... I had to do that, but almost gave up with installing it before realizing I could do that. Although that does limit the amount of drop you have from the ceiling since you have to use the longer brackets.
jmdaniel
Bought three of them the other day, have hung one so far. Pretty solid.
I want to **** the other two end to end over my double door, like some of their pictures show:
but not sure how they join them, and I don't have those vertical supports in the middle.
AdamRos19
Joliet, IL
Double up the end angle iron so one ceiling support through bolt the 2 angle irons facing away from each other. One bolt 1 ceiling brace and the 2 vertical pieces.
jmdaniel
That makes total sense. So in the end, I'll use all the parts except two of the ceiling brackets and two of the nut/washers/bolt combo used to bolt the verticals to those brackets. Thanks!
jmdaniel
The company got back to my question on this, about 16 hours after I had already hung the units. Not sure why they don't just include the info in the instructions to begin with. They did state that the combined load limit on the two combined racks drops from 1200 pounds to 900, but that's fine.
The install was pretty easy, except for the fact that the framers on my house decided to space the last joist in the ceiling at 24", instead of 16". This forced me to have to crawl into the corner of the garage attic, in order to install to cross joists, so that I had something to mount the last two vertical supports to. Gotta love folks that don't follow building plans. :mad:
Global warming forced the cut back in that extra joist. :thumbup:
Dal Bone
word of advice. Ditch the garbage lag screws that come with the shelves and get some decent ones. I had three break off while driving into the ceiling joist and another one broke off just putting some light weight on it.
After that I replaced all of them.
jmdaniel
My neighbor snapped his first three as well. Turns out he wasn't drilling the pilot holes in the wood. I did that for him, then zinged the lags right in. He was pretty amazed.
