15/32 socket?
90zcar
Going through some misplaced/mismatched stuff I found this no name 1/4" drive 15/32 socket.
Now besides someone giving me a smart *** anser of "a 15/32 bolt".......what is this for. The socket has no brand stamped on it. Only a size.
Sent from my iPhone 5s using Tapatalk
Scimonetti
VT
Are you looking for specific applications? Like gm bla bla bla interior hex cap screws? It's a normal socket that would come in a set.
90zcar
Has anyone ever used one? No it's not a normal socket that comes in sets I've never seen it in a set before
ishiboo
Oshkosh, WI
Since sometime in the early 1900s, the standard US sizes for hexagonal bolt heads and nuts have come in two flavors, SAE and Heavy. The SAE heads are 1 1/2 times the bolt shank diameter, the Heavy heads 1/8 inch larger.
A common example, for a bolt with a 3/8 inch diameter shank: An SAE standard head would be 1 1/2 x 3/8 inch = 9/16 inch. A Heavy standard head would be 9/16 inch + 1/8 inch.
Under both of these formulae, a bolt with a "odd sixteenths" shank diameter would have a "odd thirty-seconds" head.
For a bolt with a 5/16 inch shank, an SAE head would be 1 1/2 x 5/16 inch = 15/32 inch, and a Heavy head would be 15/32 + 1/8 inch = 19/32 inch.
For a bolt with a 7/16 inch shank, an SAE head would be 1 1/2 x 7/16 inch = 21/32 inch, and a Heavy head would be 21/32 inch + 1/8 inch = 25/32 inch.
It's a "normal socket", just not particularly common. I've never had to use an 8-point socket yet I have 3 of them.
mechanical turk
Monterey Bay
I have a couple that came in sets, but I think they're all cheapish imports. 15/32 is very nearly the same as 12mm, most likely the factory that made these stamped the same sockets with 12mm for metric sets and 15/32 for standard sets. It wouldn't cost much extra to do and they can sell a set as a 13 piece instead of a 12 piece or something.
jreb10
Westby, WI
I have an old Craftsman 19/32 socket, in 12 point. Is your socket old? I think many years ago fasteners came in these sizes before industry "standardized" on the conventional sizes we know today.
dynamike
9mm must be the 15/32 ugly, european sister! I have 9mm sockets/wrenches & have never encountered such a bolt head
90zcar
I'm sure this whatever actually takes 15/32 ....a 1/2" would work fine
rusty65
Pekin,IL
I've got a couple for this thread but the only one on I can think of off hand is a indestro 53/64 socket.
Sent directly from the Snap On Kool Aid factory.
wild cowboy
Birmingham
15/32 is a weird size, even for 32th sizes! - 17/32 and 25/32 are much more common for example
1/2" is a pretty poor fitting substitute for 15/32, but 12mm is a very good sub!
Stooge
South Shore, MA
I think i have a 15/32 box end indestro wrench along with a decent amount of other x/32 wrenches and sockets. I think the only time ive used it was on a 38'ish dodge brothers panel truck i was helping disassemble...i was pretty excited to be able to use it for something!
chris142
apple valley,ca
I used that size as a kid on my dirt bikes before I owned a real 12mm socket. Came from a very cheap imported set I got for Christmas when I was about 10
drew03cmc
31/32 is one I can't say I've encountered. I have a 1/2 drive SK in this size.
90zcar
I'm throwing it away! It's obviously useless....geesh there's not even a brand stamped on it!
AndrewV
Fl
90z, you stated th question good. Left little room for our smart(assyness).
But never used that size, or seen it. Keep it though. Mite need it eventually.
bobbycos
bronx,new york
Throw it away today, buy it tomorrow morning because you all of a sudden need it
jeremy v
It must be a pretty new socket to have off-corner engagement. If it were me I would keep it, because I occasionally run across 12mm bolt heads that are actually a little smaller than 12mm and the 15/32" might fit perfectly in those situations.
