$15 back in points when you spend $35 Sears/Kmart Round Two
72cheyenne
I did this a few days ago but this is round two. I have some Sears/Kmart codes I will not be able to use and would like to pass them on. All that I ask is you post that the code has been use. The expire on the 13th, 14th, 15th, and 17th so use them quick.
Expire on 7/13/14
9700033716255088 Used by OxJaw
9700033728874963 Used by ??
Expire on 7/14/14
9700033739744323 Used by ??
Expire on 7/15/14
9700033820997195 Used by PeterT
9700033821060188 Used by PeterT
Expire on 7/15/14
$10 in points on $35 purchase
9700033819997342
Expire on 7/17/14
$10 in points on $60 purchase
9700033913869224
PeterT
Toledo Ohio
Just used 9700033820997195 and 9700033821060188,, thanks a lot
I didn't mean to jump, but it looks like
9700033728874963
Expire on 7/14/14
9700033739744323
are used already
I am done, thanks again!
The Ratchet Man
Georgia
I just used 9700033728874963 aswell :dunno:
Thanks OP!
Happened in the last thread too. Both of y'all applied the same code but neither had checked out yet so it still worked for both of you. Someone used the same code as me too. I added the first item that popped up on the home page to the cart so I could add the code immediately. I then browsed for what I wanted, added it to the cart and then removed the first item. Worked like a charm. :)
