150ft pounds back killer
rlitman
Long Island
Have you ever used a torque stick? They are designed to twist at a desired torque rather than continue torquing the socket. A regular extension will do the same thing you just have no idea what the Max. torque is before it starts twisting.
This only works on an impact wrench. No amount of windup twist in the torque stick will stop a torque wrench from exceeding the value stamped on the stick, until the stick actually fails.
Putting springs under your shoes may reduce the impact you have on the ground and on your knees, but it doesn't make you weigh less when you step on a scale.
K
Kaizen
New England
Successful. Borrowed a nonslip yoga mat and used an eight inch extension allowing me to get it up to rowing height. Didn’t have to hold the head as it was not long enough to be a problem. Also used the on your knees push position and on my back pushing with legs. Tied a ******** the wrench to recoil it when I was leg pushing.
Much thanks for all the suggestions. Going to down some Advil and whisky now.
ATC
VA
Congrats on getting it done. I've done one before. Got on my hands and knees with the torque wrench in front of me. I use my right arm to push the wrench to the left, using my knees and left hand to hold me still.
You can also have someone stand close, and grab their ankle with your left hand.
Being close to 300#, it's all pretty easy for me anyways...
Catch_22
Nashville, TN
I have. Normal steel wont twist at typical loads like a torsion bar (thats what a torque stick is afterall)
Also, no mechanic I'd trust would ever use a torque stick. As rlitman pointed out you can still hammer on them an go well beyond its limits and unless you check it with a torque wrench (defeating its use) you don't know if its accurate. You cant send fatigued steel off for calibration.
So even by the forgiving torque standards of automotive work, a torque stick is not something I personalty trust.
rlitman
Long Island
...you can still hammer on them an go well beyond its limits and unless you check it with a torque wrench (defeating its use) you don't know if its accurate. You cant send fatigued steel off for calibration.
Actually, this is EASY to test. Just draw a line straight down the length of the torque stick. If it is fatigued, the line will show the permanent twisting. If the line remains straight (when not under stress), that is proof positive that the stick has never fatigued.
Still, I wouldn't advocate using a torque stick here, or for torque critical uses, but I do like my torque sticks in the case where I want to run the torque up with the impact but finish with a torque wrench. I'll just select a stick that's a step or two below the final torque.
If you do this, the line test above is unnecessary. This is because once a torque stick has begun to permanently twist (as it exceeds its elastic limit and starts to plastically deform), I would expect it to eventually twist off due to fatigue, and we have heard absolutely no stories about torque sticks snapping, so I would guess that this is just something that does not happen (no surprise here, as they're engineered for the job). And more importantly, once the torque stick starts to fatigue, it will deliver LESS torque to the fastener. So if followed up by a torque wrench as I advocate, a torque stick cannot cause any harm.
So all this talk about torque sticks being evil is just by people who do not understand how they work.
