1700 sq/ft Bright white floor
INTMD8
Lake Villa Il.
I thought I would put up some pics as I was able to finish my floor today. After looking at a ton of pics I decided on a pure white floor with no chips.
Materials are from Legacy and consist of-
6 gallons off white standard primer
9 gallons super hide white HD epoxy
6 gallons super hide white urethane
3 gallons gel crack filler
I started with a 4.5in diamabrush around the entire perimeter of the shop. This was done before the steel walls were put up.
Next was filling all saw cut's with backer rod and the gel crack filler. Most of this turned out seamless in the end but there are a few spots you can see through the coating. I think the liquid stuff that's poured onto sand would have been easier.
Next was grinding the floor. Had no luck with rental diamabrush setup from Home Depot. Took over 4 hours to do 100sq/ft and still missed a lot of spots. The surface of the concrete seemed very hard (it was poured in 99) and also not extremely flat.
Sooo, I decided to grind the entire thing with a 7" grinder and a diamabrush. (I needed 2) Lots of work! Let me tell you I did not enjoy it but felt 100% confident it was profiled correctly. Blew everything out 3 times with electric leaf blower then very slowly vacuumed each section.
Next was burning the fiberglass hairs from the surface with a weed torch. This was only partially successful as there are still some areas that had little fiberglass nuggets sticking up. I cut off most with an exacto knife before applying the urethane but you can still see some up close. I then cleaned and vacuumed the entire place again.
I didn't want the white peeking out from under the door so a line was cut into the floor just inside. Masked off and used a clear sealer.
Once that dried I closed up the shop and masked off everything next to the floor. It was high 80's and humid so I ran the A/C until it was 62deg and 45% humidity.
Scotty mentioned that wasn't enough humidity so that was changed to 70deg and 69% humidity for the urethane top coat.
I used an old pair of shoes to make some 'spike' shoes with elevator bolts and fender washers. They worked great. Set everything out and mixed up the first batch of primer. My girlfriend helped me cut in the 2 epoxy coats. I did the urethane myself as there was more time to work with it. Some more help may have been easier but I didn't trust anyone to not mess it up, miss a spot, whatever.
IMG_2315_zpsobflzco5.jpg[
Everything went down nice. I had a spot that I believe the primer was too thick which resulted in about 5 little bubbles from outgassing. I cut them out with an exacto knife before applying the urethane top coat.
I will mention I was slightly nervous before the top coat as the epoxy cured a bit streaky and you could see a lot of roller marks even though I backrolled it each direction twice.
The urethane top coat however seems to cover extremely well and as soon as it was going down I could see no color differences or roller marks. Only needed 3.5 of the 6 gallons.
Not perfect but still looks super nice! :D
James-W
Southeastern Wisconsin
Think white car. They look pretty good even when dirty.
I never had a white car, but many years ago we had some white carpeting. If you had any dirt at all on the carpet, you could see it plain as day because it stuck out like a sore thumb. After about 18 months we finally ripped it out got a tan colored carpet. Later on we moved to the house we are in now. But the point is that the light color made dirt seemed to be more noticeable that if the color were a bit darker. I was just wondering how it would work out for garage floors which do have a tendency to get dirty.
I
INTMD8
Lake Villa Il.
Thanks guys! I wanted the highest light reflection. I'm sure dirt will be more noticeable than if it were a darker/chipped floor which is why I plan to keep it clean.
lane_change
Amazing looking flooring. If I go Epoxy, this is the exact look I will be going with for the same reason....light reflection for underneath the lift. The level of work you performed however scares me and is part of the reason I debate sacrificing the reflective qualities of a white epoxy for the simplicity of a Racedeck installation.
I
INTMD8
Lake Villa Il.
No, there are no lights at the moment. Once the floor is cured I'm going to move in the rest of the equipment and then have the electrical done.
Angelfire
New Mexico and Ireland
Reminds me of the song "I wear my sunglasses at night" for some reason.
Having aging eyes myself, I appreciate the effort to maximize reflectance. Curious to see how it all works out once you get your lighting in.
streetdaddy
Nashville,TN
Amazing! Just the look I'm going for.
I'm going to try the Rust Bullet brand as it looks a little easier to install for this noob.
Thanks for posting!
Mr onetwo
Coastal Maine
Great looking floor and shop! I love the all white look, but I don't know about keeping it clean if you do any sanding, body work or welding/grinding. Please keep us informed on how slippery this floor is in real life use. Thanks
Shea
California
Great Job! You can pat yourself on the back for handling such a large area so well. You may able to see the dirt more, but it's nothing a good commercial dust mop can't clean up in short work.
JCQuick
Apopka Fla.
wow that does look good and when I read the title of the thread I said Naa that wont look good. I stand corrected
Trey T
Houston, TX
I love it.
When I chose my floor colors, I chose beige for primary color thinking that it was a too white/bright. Now, over a year later, I wish it was white.
benwah
Lakewood, Colorado
I would be willing to bet the streaks came from actually back-rolling too much. Twice is a lot, twice in each direction is a lot a lot!
Once 100% solids epoxy starts to cure (which happens quickly) it's best not to disturb it and let it flow and even.
Great looking floor! This is my favorite type of floor, one solid bright color. Looks awesome, good job!!!
I
INTMD8
Lake Villa Il.
Thanks guys!
benwah, you are quite possibly right, I noticed it was feeling a bit sticky on the roller but I was freaking out I couldn't get it to look even.
I opened the door today, 26hrs later and it looks great! Couple of bugs and about 5 spots where a very thin bubble was created (when I pulled it off you could see a pinhole). Otherwise seems to have set up very hard and is uniform and glossy.
Oh yeah, since my shop has no windows I just about got knocked over from the fumes when I opened the door. Gonna have to air out a bit :)
Denwood
Thunder Bay, Ontario, Canada
Excellent choice on the white. Since doing my own shop floor white, I've been recommending it. Invest in a decent push broom and industrial mop/bucket. The floor is no harder to keep clean than any other color..perhaps easier as there is no chip texture in the finish.
The level of reflected light with a vehicle on a hoist is impressive, and dropped parts etc will be a snap to find.
GDPossehl
Atlanta, GA
This x1000
I look at a lot of those heavily flaked floors and think of how bad it must **** when dropping an important screw or bolt. I would do a perfectly white floor in a heartbeat. It will also help you keep it cleaner because you can actually see what needs to be cleaned up.
Great job OP. You have a great attention for detail. I didn't even notice in the first pictures that there was no interior lighting installed yet.
Armorpoxy
Agree, fleck floors make it hard to find small parts and such. We have actually had customers who didn't know about this problem recoat perfectly great floors with a solid color so as to avoid their mechanics complaint's!
We find that our Light Gray color which is almost like a light 'Pewter' reflects light great, but is easier to keep clean.
LegacyIndustrial
deerfield, IL
This x1000
Agreed. Important to coat the epoxy with our HD322 HP pigmented urethane. This will keep it nice much longer than epoxy alone.
Armorpoxy
All epoxies, by their nature, are not inherently chemical/dirt/stain resistant, and if not topcoated will be hard to keep clean and new looking. Light colored epoxies can yellow so the topcoat greatly helps to prevent yellowing.
Especially important to topcoat if using flecks, otherwise lots of dirt collecting edges, even if they settle into the 100% solids epoxy coatings.
Nighttrain
Dripping Springs, Tx
I've been in a lot of hangars with white epoxy floors and the seem to hold up and look great for years. Easy to clean and most importantly you will see any leaks from the aircraft. The tires on some of the jets are pretty hot when they roll them in. I have noticed that most will have floor mats that they will roll the aircraft on. This helps with tire spots but also to ensure the aircraft is in its spot when placing multiple aircraft tin a tight hangar. Nice write up OP, you have my interest back in epoxy for my shop. I'm looking though for more of a tan/cream color to match the theme.
JCQuick
Apopka Fla.
I must say I'm being swayed towards a white instead of a gray like my attached. I will be adding some flecks thou
jives
Central NY
Those are Starwood rafters, are they not? We strongly considered using them, but wanted a steeper pitch than the Starwoods allowed.
I
INTMD8
Lake Villa Il.
Good eye! Yes they are. I installed them in place of the existing standard trusses in order to gain needed clearance for the lift.
