18v cordless drill issues
Sam_i_am
My cordless hand drill uses an 18v battery. I have two of these batteries to alternate use, and a charger to keep them charged. Both batteries are totally dead and will not charge. The charger is producing 41 volts ... obviously much higher than its suppose to be.
How can both batteries be dead (0 voltage) and what would make the charger put out 41 volts?
Fried electronics in the batteries from over voltage? They May still have a charge in the cells, but the smartness on board won’t let it out?
Guessing here.
Sam_i_am
I was able to jump the 2 bosch batteries into a state of positive voltage. Both will power the drill to a degree. I won't be leaving the batteries on the charger at all. So maybe the batteries can be saved, but this charger is not right.
Any one knowledgeable as to what would make this charger put out 41.?? volts when it is supposed to be rated at 7.5v to 24v?
Can it be fixed?
niget2002
Josephine, TX
How are you measuring the voltage on the charger? Is a battery hooked up while you're measuring it? If not, it could be the charger trying to 'jump start' a dead battery by overvolting it because it's reading your meter as a 0 volt battery.
Sam_i_am
Yes, with the batteries NOT charging. Because of the charger and battery design it does allow testing while the battery is mounted to the charger station.
I will rig up something to simulate.
Sam_i_am
edit: Because of the charger and battery design it does - NOT - allow testing while the battery is mounted to the charger station.
Sam_i_am
Thank you for doing that Cobbler, I really appreciate it. I haven't heard much more about this (Bosch) charging sytem.
The one I have seems to be over charging and yours appears to be under charging. Weird!
American Locomotive
Rhode Island
The voltage without a battery connected is irrelevant.
I'm not saying your charger is working correctly, just that modern lithium chargers are not simple transformers.
Sam_i_am
Roger that American Locomotive. I understand the complex circuitry that some chargers may contain within them. And to that end, charging devices may not indicate true values when not in use. I am only hoping to findf a common denominator for the Bosch BC130 battery charger in its "plugged in" non charging state.
Since the 18v drill is still in working order I'll either need a new charger, a new battery or both to put it back in service.
Nutshell: hoping these chargers have a factory set "plugged in" but "not in use" voltage to determine if my charger is with in specs.
Thank you for the comment, appreciate it!
AEAdam
SE PA
I have Bosch cordless tools. Just note there are multiple 18V batteries like the (newer) CORE batteries. They cannot be charged with the old fast chargers. Just make sure your batteries are compatible with your chargers.
And FWIW, I've had my Bosch 18V for probably 10yrs and all my batteries still run great. I use them every weekend. Stored in an unheated space.
Sam_i_am
Anyone who has owned one of these drills knows why I wish to continue its use. I've ordered a charger and battery set.
Hopefully I'll end up with 4 batteries or 2 chargers ..... we shall see!
AEAdam
SE PA
but if they're not compatible, so they still fit?
Yes. Compatible. Fit the tools, fit the battery charger, but will not charge.
The Bosch CORE Batteries, which are very nice, don’t charge on the old rapid charger. They will charge on the original smaller slow charger.
