1926 ford model t tudor project car
endmill
nashport,Oh
Mt Vernon Oh
Listing this for a friend of mine. Don't SHOOT the messenger:scared: You can contact Call Denny Miller @ 740.507.9361 Price $7,850.00
If you want more just message me with you email. Thanks Dave
negotiable and serious buyers only.
Engine and transmission - need assembled - engine rebuild by Jack Putnam, work performed in 2008
Alum Pistons Size .030
Weight Matched Connecting Rod .020
Sm. Timing Gear/steel
Rebabbit Mains/ .020 / Align / fit crank
Fit Connecting Rods to Crank / Drill X Caps
Ream Valve Guides .030
Machine Block and Install Valve Seats
Reface Valve Seats
Machine Block/top Deck
Test Fit Pistons/pins
Bore and Hone Cylinders .030
Ream Lifter Bores Oversized .015
Grind Crankshaft Mains .020, Rods .020
Spray Weld Crankshaft Seal Area
Resurface Rear Flange of Crankshaft
Partial List Of Parts
Universal Ball Cap, Rebabbitted
New Valves / Stainless +.030
New Valve Springs
New Valve Spring Retainers
New Valve Pins
New Tappets SGL Lock +.015
New Modern Cam Seal
Alum Piston Rings +.030
New Touring Camshaft
Rear Camshaft Bushing
New Timing Gear, Bronze
Trans Reverse Gear Bushing
Trans Slow Speed Bushing
2 Trans Driven Gear Bushings
Trans Dr. Plate Bushing
Triple Gear Assembly (used) Non Riveted
Trans. Triple Gear Bushings
Trans. Triple Gear Pins
Trans. Brake Drum 1926-7
Trans. Slow Speed Drum, New, U.S. Made
Trans. Reverse Drum & Gear N.O.S.
Modern Turbo 400 Clutch Disc. Set
Rebuilt Mag.
Many more parts and tools.
New tires - tubes
