1940 - 50s GE Motor wiring
easton65
North Central, AR
I have had this motor for about a year now. I found it in a barn, and I guess it was my great-grandpa's. I cosmetically restored it, long story short I'm varnishing the windings tomorrow. I'm a bit confused by the terminal plate for this motor. The original wiring was neutral to 4, hot to 3, and a wire ran from 3 to 1. It worked in this config. I wired it to have hot on 3 and neutral on 4 and nothing else, it also worked like this. Im not sure what post 1 was used for, though. Could it have been for a start cap? The contacts would be connected when the start winding was not in use, so that's the odd part. Polarity in this case obviously doesn't matter. Any ideas?
Specs:
1/6hp
1725rpm
3.8a
Model 5KH43FD12 (KH model so no cap)
bmwrd0
Beaver Fever Oregon
I doubt there was a start cap at 1/6hp. It is more likely a shaded pole, and the phase shift needed to get it started is in the wiring. If it isn't, it would be a split-phase, which is like a cap start, but without the cap, and just using the magnetic effect to get it started.
If you switch post 1 and 3, I would be willing to bet it will reverse, which would be the point of the second pole.
E
easton65
North Central, AR
Yes, it's split phase. I just got done varnishing the windings, too. I also edited the model number in my first message. I entered the model for one of my other motors by accident.
