1941 Avey Half Heavy Restoration
OK this was a big project, but I'm really satisfied with the result. I wanted a benchtop drill press....
This facebook marketplace ad caught my eye.
$75 later and it was mine. My brother picked it up on the east side of the state and dropped it off to me. We had to disassemble it to lift it out of his car. It weighs around 400lbs.
It took some time to sleuth out what it was. Turns out its a 1941 Avey Number 2 "Half Heavy" made in Covington Kentucky. They made all sorts of drilling machines and this is one of their smaller units.
Its got an integrated 2spd 3 phase motor (1hp)
The two speed gearbox in the head, as well as some belt options, allow for 8 speeds, originally from 1200rpm to 12,000 rpm. All shafts and the quill are ball bearing supported to handle the speeds:
The motor speed switching is done via this neat old contactor that is hidden in the column of the machine.
These are the quill bearings, with my hand for reference
So i tore the old girl down and removed all the varnish, paint, and rust.
I used evaporust, aircraft stripper, and lots of wire brushes to get everything clean.
I found some old drawings for her, and was able to source all new bearings. Most the old ones were in good shape just dirty/rusty. I figured new was in order while it was apart though.
There were a lot of ancillary boxes and **** hanging off the castings. I welded closed all the extra holes.
Lugged it all into work where we have a small paint booth. I did some light autobody filler on her
Epoxy primer
Topcoat is Nardo Gray from Audi/Lambo. Its a single stage:
Started reassembling her.
I bought a Hitachi vector drive VFD and hid it behind the back cover of the machine, where that contactor used to live. This was necessary to be able to run the 3phase motor from my single phase 240v service. This VFD is really neat. Sensorless vector VFD's are wild for anyone used to old gutless drives. These provide the motor with constant flux by varying the volts/hz ratio. That means you get full power across the entire speed range.
Cleaned up the tags:
Designed and machined up a steel fixture plate. This uses the same 5/8" dog clamps as my welding table. Its also setup with 1/2-13 holes to accept typical machine shop workholding.
The 3/8" Jacob's original to the press was not really my favorite, and it had a bent jaw. You can still get rebuild parts for it, but instead i sourced this 1/2" capacity ball bearing vintage jacobs keyless (actually a Llambrech, made in Spain)
This chuck is my favorite part of the press
Finally the controls. I wanted to use the original momentary switch gear. I wrote a program and flashed the VFD with a neat control scheme via its USB port.
Far left is the high/low shift lever for the gearbox. In from that, the black momentary push button starts the machine in forwards. Press again, and the spindle decelerates and reverses. When speeds are low, this accel/decel happens very slowly, which allows me to tap holes, for example at 35rpm. The red button is for stop, or press and hold to engage the braking resistor for a quick stop. The knob on the far right controls the speed.
I swapped pulleys and set the VFD for 0-100hz command, to give me a speed range of approximately 0 to 1800rpm. I designed up a custom nameplate for the controls and had the local trophy shop laser etch it
The last step was the belt guard. I used a slip roll and some thin stainless to make this.
I spent a couple of months on it, but I hope it lasts a lifetime
Bob/Ohio
Very nice job on your restoration and VFD conversion! I bet it runs as good as it looks!
Bob
kevink1955
Suffolk Ny
Very Nice.
The drill press has always been my favorite machine to use for grabbing and throwing random pieces of metal across the shop Lol
1982fxr
Phoenix
That's awesome.
I gotta ask though, if it's 400 why is it assembled on the floor? I'm asking on behalf of your back:)
Or is that actually a bench top?
Looks great, hard to believe 400# in such a small package, except for your picture of the massive column.
Packard V8
Spokane, WA
Exceptionally nice work.
I've got a big old Avey floor model earlier than yours; flat belt drive. Still I can see the family resemblance in some of the design.
jack vines
M
Thanks to everyone who commented, you guys are really flattering. I am excited to share some of my other projects!
I do have any videos of it, but i appreciate the idea. Will see if i can get to that.
I've used it a dozen times now and I don't find my self using the lower end of the quills slide adjustment at all, even with very small drill bits. I am considering a small "spacer" between the column and the base, to give it a bit more throat. Perhaps 2 or 3 inches thick. I am not quite sure on the fabrication method of such a spacer yet. CNC machined from a chunk of durabar iron would be slick but I'm unlikely to pony up for that $$$. Also considered a welded assembly of two plates and 4 standoffs, skinned in sheetmetal and painted to match.
SweetD
Rhode Island
One of the nicest and most well-thought out DP restos I've seen here on GJ. Just wow. Thanks very much for sharing. I for one would love to see some of your other projects.
:beer:
Dave
M
It looks like maybe the imgur linked pictures are no longer working in my thread. Sorry about that.
I have an album here if you need more info: https://imgur.com/gallery/0VjNwus
I've been using this drill a ton and it works really well. I recently made a short video about a part I machined with it!
