Hello All,
I just picked up this 14” Delta Milwaukee drill press at a very small estate sale along with a 1967 Powermatic 143 bandsaw. The drill press has a serial number of 49-6695 so I’m assuming it was made in 1947. It has the third set of pulleys for slow speed. It has a Jacob’s 6A chuck and original chuck key. It’s in excellent condition for a drill press built in the 1940’s. The motor is not original and is a 56 frame Dayton wired for 115VAC. There is no on/off switch. I have a couple questions;
1) Was this drill press built in 1947?
2) Other than the aftermarket motor, fo you see anything that stands out as not original?
3) While I’ll likely keep this drill press for personal use, what would you estimate its current value at?
I paid $650 for the DP220 and the Powermatic 143 as a lot. The 143 was built in 1967 and is in great shape and only needs belts and tires. Bearings are all good on the guides, arbors and transmission, paint is good with light wear marks.
Thanks
Thanks
