1958 Craftsman 12" disc sander
Hoorn
Glendora, CA
Several weeks ago I bought this Craftsman 12" disc sander.
I have dated it as 1958 for the following reasons. In 1957 the optional motor offered was a Dunlap 1/3 HP. In 1958 the optional motor offered was a Craftsman 1/3 HP. This motor is dated July 1957. Also, while disassembling the sander I found the original paint scheme to be power bronze on every piece. This happened for a very short time in 1958 before Sears switched to an accent color with the power bronze and would make the motor end caps dark brown going forward.
This was the condition when I picked it up:
This was one of the toughest restorations for me in terms of grime removal. I bought this from a machine shop going out of business and it had decades of oil, metal shavings and grime built up. For the portion underneath the table I was resorting to extreme methods of crud removal.
At any rate this was my first crack at Craftsman's split phase motor and I really enjoyed not having to deal with a capacitor and the excess of wires that it brings. I replaced the original New Departure bearings with Nachi and thoroughly cleaned up the copper windings. The motor runs virtually silent and is very strong. The cast disc creates quite a bit of wind noise and of course takes forever to stop.
One last note. As 11b mentioned in his classic Craftsman drill press thread, champagne mist is a dead ringer for power bronze.
In the picture below the trunnion still has its original power bronze paint. The lower trunnion piece with the red arrow on it is painted champagne mist.
I will also add that 3 days after the champagne mist dried, I applied a satin clear coat. The champagne mist only comes in high gloss and Craftsman did not paint their Long C/Heritage/Crowntop era machines with high gloss paint. High gloss has a cheap plasticky look to me on these old cast iron machines and is not era correct.
woody 73
The Great State Up North
Very nice good job(y)(y)
For some reason old craftsman power tools never worked for very long, in my old eyes. Not sure why but the magic smoke would always rise up and that was the end of it.:eek:
I gather that old girl will be going strong long after we are all turn to dust...
H
Hoorn
Glendora, CA
Appreciate that gentleman. It's just a cool looking sander.
I had never previously run across, or heard of any Craftsman branded machines from "Double A Products Co", Sears vendor number 109. Double A was located in Ann Arbor, Michigan and by 1957 became a division of Brown & Sharpe.
bmwrd0
Beaver Fever Oregon
I have one of these out in the back shed, waitin' on a resto. Nowhere near as pretty, some former owner painted it JD green, but it has the 3/4hp duty rated motor. Which is nice, as that will burn through end grain like no one business.
H
Hoorn
Glendora, CA
Can't wait to see that bmw! Get crackin' brother, that will make for some amazing glamour shots; especially with that 3/4 horsepower!
Jayman17
Seattle, Wa
Hoorn, very nice resto job on this sander. I would love to pick up one of these old ones or a Delta too. I don’t see just the disc sanders around my area very often.
Jay
H
Hoorn
Glendora, CA
Jay
Thanks Jayman. I'm working on a 1937 Delta belt sander right now, that will most likely be my go-to sander. I tracked down a cast iron pulley cover recently and I'm pretty excited about getting it all together.
gatewaysysop
Arizona
Wow, what a beautiful restoration!
I've always thought these disc sanders were nice pieces, but I've yet to come across one locally. Hope I find one even a fraction as nice as yours turned out. Awesome work.
H
Hoorn
Glendora, CA
Thanks Gateway, I hope you find one as well. Here is the original ad that I responded to:
The obvious Craftsman pedestal was not original to the disc sander. To my knowledge they did not make one specifically for the 12" disc sander. Every pedestal that I have seen had a direct bolt pattern for the specific tool to the pedestal top, this one has adjustable feet at the back and perhaps that is why they did not make a pedestal for it. That pedestal belonged to an 8 in Craftsman table saw.
The pictures don't really show how filthy this thing was, particularly under the table, but don't be discouraged if you find one that looks pretty thrashed.
JoCoSawdust
Eastern NC
Indeed it is!
Double A Products most prolific contribution to Sears was the 109 metal lathe that was branded at various times as Companion, Dunlap and Craftsman. They also made the small Dunlap branded version of the Mohawk DP.
H
Hoorn
Glendora, CA
Indeed it is!
JoCo, thank you. You never fail to impress with your vintage Craftsman lore.
Smokeshow69
The sander BMW references is this one I just got from him. I am thankful it was entrusted to me!
BSWS
Tucson AZ
I just came across this thread and I love this sander, you did a great job on it. I've been searching for an old sander and have never seen one of these. I'm just getting started into a Crafstman 150 drill press rebuild. I'll need to start searching for one of these sanders for my next project. Right now I'm using a bulky Shopsmith as a 12" disc sander, I'll be really happy to get rid of it.
Smokeshow69
Be forewarned this sander and accompanying motor are unbelievably heavy. When you find one you will want to make sure it’s in a base
Loghead
What an amazing job! I just picked one of these up at an auction and according to your expert knowledge mine must be a 1957 as it has the Dunlap 1/3hp motor. It is in great shape except it is missing the bracket that holds table on, the one that you have pictured above with the red arrow. Would any body happen to have any spare parts laying around for this gem.
H
Hoorn
Glendora, CA
@Loghead you are looking for the table trunnion. They do pop up every once in awhile on eBay. It will have to be specific for a 109. Sears vendor model. Happy hunting and in the meantime if the bearings need replacing you can start on that.
BSWS
Tucson AZ
It was last Oct 1st that I first came across these pictures. I'm blaming you for this obsession I've been dealing with since then. Now I can comfortably say my daily searches for one of these is nearly over, I'll have my hands on it next week. I use the 12" sanding disc on my bulky, otherwise-useless Shopsmith nearly every day. I'm looking forward to rebuilding this, then enjoying it as much as I do my recently completed 1962 CM 150 drill press. Then it's on to the next project I'll be obsessed with soon...whatever it is.
