1970's Craftsman ratchet questions.
ScreechAwl
Did Craftsman ratchets of this time period come with grease in them? If so, what was the point of the oil port on the top of the ratchet head?
I recently disassembled a used craftsman 1/2" ratchet from the late 1970's and found crusted orange-colored grease on the pawl and the main gear. I try to take into account what the original factory lube was before I re-lube (along with tooth size and tooth wear). I've already used Superlube on some of my ratchets and motor oil on others.
davethorik
Norka, Ohio
The "oil port" is just a hole left from factory drilling the cavity where the spring and ball bearing go.
