WWIIFAN
My father had a new Morton 30x40x10 built in 1978. 4" cement floor. One 16x8 door, a 10x8 door and a walk in door. It has the pink foam board insulation with white foil covering installed under the tin by Morton during construction. It is wired and has an LP furnace.
Question I have...??? I'm needing more room. I thought about building another 30x40x14 right beside it and tie them together? The killer here is the floor in the current building has broke in several spots very badly. As in the cracks are over an inch wide in places.
So do you remove the floor and pour a new slab? Or do you tear down the current building and start from scratch?
This is the older 6" treated square pole construction Morton by the way.
Thanks...
Thanks...
