One of the problems with using chemicals inside your tank is sealing all of the openings properly. The fuel cap hole is round so I was able to find a rubber plug at HD that worked well. But the petcock hole is oval, and the fuel sender hole is a large rectangle. I ended up using what KBS suggests which is good quality duct tape. It mostly worked, but I did still have some leaks no matter what I did. I think that had I spent more time here coming up with a better stopper solution I would have been better off. I did use fresh US made duct tape so YMMV with a different or batter tape.
Here is an example of the tape wrapping:
The KBS Klean is mixed 50% with hot water. I used 1/2 the bottle with that much water each time for two separate washes. Each time that I washed it I flushed the tank with water and then dried it. (More or drying later.) I wasn't super happy with how clean it was so I re-did the wash again by reusing one of the washes I used before. If you let it sit a day or two the crud it picked up precipitates out so it's relatively clean to re-use.
You really need to do this step thoroughly. I put two 3 foot pieces of chain in the tank and I would rotate it and shake it for a couple of minutes. Then I'd leave it in a position to soak one part of the tank for 15 minutes. I did this process for a total of 2-3 hours each of the three times I cleaned it. It's a tedious process but it's critical to the later steps working. Depending on how well the tape was holding up, I might have to replace it during the process as well.
It took me awhile to figure out the best process for my tank and drying it. This is what I eventually came up with:
- Drain the tank as best as possible. This involved a lot of passes of trying to get the water to concentrate near the petcock and then moving the tank just right.
- Get out the yard blower and let that thing run into the tank for 5 minutes or so.
- Take the tank in the shop and note that water is still moving around. :-( Get out the heat gun and move the tank around so the water is concentrated around the fuel sender hole. Use the heat gun to evaporate the water in that area. Repeat - lots. It took maybe 10 passes to get all of the water dried out...
After the clean process the next step is rust. The process is similar to the clean but no chain this time. The solution is put in at 100% this time. And the instructions are bit different as you can't let any part of the tank dry out for more than five minutes. So my process was to move, shake, tilt, and turn the tank for a couple of minutes. Then set the tank down to rest in a specific position. Wait 4 minutes and then repeat ending in a different position. I did this for almost an hour and a half at which point I was done. Pour it out, rinse, and then dry totally.
The rust cleaner also puts a zinc coating on the tank which really helped with the flash rust. This isn't the greatest photo, but here is the fuel fill after the rust treatment:
You can see that there is still a bit of rust there, but it's largely gone without any large area of flash rust. The instructions say that some rust left is ok.
The final step is the coating. After my bad experience with Kream I spent a long time thinking about this before I decided to do it. After all, most of the rust was gone now and I could just use the tank at this point. Also if you botch the previous steps, or the coating step, the coating is very hard to remove so you can redo the tank. (They do sell a coating remover but I've got no idea how well it works.)
The coating is a different process in that once the coating is added you have to move/rotate/tilt/shift the tank for 30 minutes without stopping. The end result is that you want a thin coating over all of the tank. So I taped the tank, poured in coating, and listened to music as I worked out moving the tank for the next 30 minutes. No shaking here, just a constant gentle movement.
I filled the four sender screw holes with M6 screws as well the two petcock holes. After I had drained the extra coating I removed the screws and cleaned out the threads with Q-tips. I then put a different screw back in to make sure that the threads were both Ok and clean.
Also, after the Klean step I had a question for KBS. They were very quick to reply to both a phone call and follow up email so I was very happy with their level of support.
One issue that I had is that no matter what I do I can't fully empty the tank. So for the last bit of coating I tried to move the tank into different positions to try to thin out any remaining stuff and not have it puddle. If the coating is too thick KBS says that it may not adhere properly so there is some chance that I may have issues later. But so far from what I can see it looks great.
Here is what it looks like two days later:
When you touch it it feels like glass. It really seems like the coating adhered well and is ready to protect my tank.
I still have to get the drained chemicals (Klean and Rust Blast) to a local recycling place, and at the moment I don't know if they'll take them or not. So that is a potential down side from this process. The coating was easy as I just drained it onto cardboard and then let it dry to go in the trash.
Also the vinegar submersion process messed up my tank's paint. The first immersion caused all of the bottom paint to flake off, but that was easily covered with Rustoleum. It's on the bottom so all it needs to do is not rust. But the second immersion caused some orange peeling on the upper paint plus it weakened the paint. So there are a couple of areas where the later duct tape peeled off my nice upper paint. So it looks like learning how to paint a tank is in my future as well. This is probably my fault as I immersed the tank two days the first time and three days the second time.
Anyway I have a good inner tank now and I can finish up the last bits. I need to synch the carbs, rebuild the front brake, and add a tube to the rear tire to have it mechanically done. And I need to clear up the title, which may involve a trip to CA. But hey, I'm retired so I have lots of time.
