metalhead212121
- Joined
- Mar 21, 2010
- Messages
- 2,898
I changed a lot of gaskets. Oil pan, pickup tube, valve cover, timing cover, oil galley, egr valve, intake plenum, t-b, new egr pipe, new valve cover grommets.. Should be leak free when it fires up. Not going to be for a while. I've been working on the truck a bit. Nothing too exiting.
Be careful saying that... I recently resealed a engine that leaked oil from EVERY gasket. When I say every gasket I mean EVERY gasket. When all was said and done the engine ran good and didn't leak oil from anywhere. A week later it started to knock! Ended up needing a rod bearing. Fortunately the oil pan was the ONLY gasket I didn't replace. Put new rod and main bearings in.. no more knock. Down the road I realize the POS swallows oil! Like a quart every 1000 miles! Sometimes you get lucky and sometimes you get fucked.
I couldn't drive the POS because I didn't want to insure and register something that would just sit in my garage. If I HAD driven the thing daily I would have realized how much oil the POS ate.
