pauls_workshop
Hi all, I'm a newbie here and about to do my first epoxy flooring job with a basement workshop project. I have about a 1 car garage amount of space for this workshop room. I wanted to present my rough plan and ask for advice here or anything anyone can help me with issues from my rough plan. I don't have tons of money to spend on the floor and I want to save money on it where I can, but I do want to do it right, have it last a long time, and not have any problems with it.
1. Shop floor has to be done in 2 runs due to stuff that can't be moved out of the space available. House is from 1986. The floor is cement and had a sealer on it. I've used a 4.5" dewalt diamond wheel grinder with harbor freight little grinder to remove the sealer and get down to about an 80 -100 grit sandpaper texture. I've just got the first 1/2 done. This takes alot of time but does the job cheap. My cost is $60 for a wheel to do all the grinding on my project (i had the grinder). I'm not planning on using any acid etch.
2. I have a 1 car garage kit of Valspar 2 part epoxy in gray that I got several years back at a garage sale cheap. I was originally thinking of using this for the basecoat. I also bought a Valspar 2 part epoxy topcoat recently. Some know these under quickrete name prevously (all made by Valspar). Well, talking with a friend who has done some floors for factories with epoxy, and reading the excellent forums here on epoxy, I've decided to go with a better kit for the main coating and have on order a 1 car garage kit from epoxy - coat instead I'll get in a few days. It should be about 10 microns thick vs. about 2.5 in the Valspar water based kit. I'm using chips so do want a clear finish coat on top. I'm thinking the Valspar as clear on top the epoxy-coat should be OK, if applied at the 18-24 hour window epoxy-coat recommends for the clear coat. Any thoughts on this? I want to save money on the clear if I can and the Valspar is cheaper than the epoxy-coat for the clear. I figure if the basecoat is very good, if the clear wore through eventually in the wood shop, then I could always just add another clear coat in future years no problem, but I want that basecoat right.
3. I do have a small crack in the floor and also small chipped out areas where carpet tacks used to be in the basement. So I have to fill those. I bought a 24 ounce 100% epoxy solids repair kit in Rustoleum format to do that. I was thinking of mixing in lots of silica sand with that to patch the chipped out areas and stretch the epoxy for that. Is about a 2:1 sand to epoxy ratio about right for this? I'm assuming this should be OK for this but tell me if I'm wrong.
4. I've read LOTS here about the benefits of using a primer under the epoxy, even though epoxy-coat doesn't require one, but the ones recommended are hundreds of dollars = as much as the epoxy basecoat! Are there no good primers that would work fine that are cheaper or available at the home stores that would work? (I have a Menards, Lowes, and Home Depot here and a Sherwin Williams and ICI store too) I was thinking - since I have this Valspar gray kit I wouldn't otherwise use, could I use THAT as the primer coat under the nicer thick Epoxy-coat base? The primer coat I've read is supposed to go into the cement pores good - well a water base 40% solids coat might be better then as a primer coat than a 100% solids one, right? Is this a good idea or a terrible one? I think there was a ppi primer about 40 or 50% solids I saw mentioned? Thoughts on this using the valspar kit as primer?
5. My floor also had the cement poured after the block walls were put in, so I have expansion joints at the perimeter edge of the floor all around to the block. I think best to allow expansion to happen if it needs to, so I'm planning on filling using Sikaflex self levelling on top of the foam backing and not ever epoxying over those joints. I don't want epoxy to crack over the joints and can't see how to avoid that really. I can paint with a little darker shade of gray paint though on the Sika and I think look OK.
6. What is best way to clean off the cement just before the epoxy? Water many times with mop? Denatured alchohol alone? right now it is very dusty.
7. How best to minimize the line between the two sections I'll be doing? Will the clearcoat just hide that completely or not?
Experts, please help out the new guy here with your thoughts. I'm amazed at the great community here and all the help from installers, suppliers, and successful do it your selfers. This is truly a super special community that I'm glad I just discovered! Thx in advance! - Paul
