Dan in Pasadena
Okay, here's the photo (iPhone photo, sorry)
This is flux core .030" wire in a Hobart Handler 140 on the web of a 10" deep, 4" wide flanges I beam. These welds are on the web which is probably at least 3/16" thick. I've not welded since college. That was stick and oxy-acetylene and I SUCKED at it especially the stick welding. BUT, I've been studying....Youtube videos, reading here and elsewhere.
The middle bead was "pulling" w/comfortable body position. I'm left handed so progress was right-to-left.
For the top bead I switched sides, pushed and rested my hand along the flange to try to steady. I think the results are, "Eh..."
Probably should have used the flange but pulled.
Bottom bead was done w/poor body position frankly and I THINK my progress was too fast, that's why the filler piled up instead of penetrating like the other beads(?)
I had a machine malfunction as I started - I'm sure it was my fault somehow but the wire broke entering the gun. I probably wasted 10 ft of wire figuring out how to fix it, but I did and all was well after that..I just ran out of wire fairly quickly.
Feel free to criticize. If it *****, tell me. If you have suggestions, let me know.
I am doing some structural work in my garage welding beams together to open the rear. (A $700 welder quote will make you do all sorts of things, lol)After that, I'll likely ONLY be doing sheet metal repair on my '55 Chevy truck. I'll be using MIG and .023" wire. MUST I go back to flux core for the beam work or will the mig work? Too small?
Lay it on me fellas!
Probably should have used the flange but pulled.Bottom bead was done w/poor body position frankly and I THINK my progress was too fast, that's why the filler piled up instead of penetrating like the other beads(?)
