1x42 belt sources?
larry4406
Northern Virginia
I need to get some belts for my Delta belt sander/grinder. Where do you buy your belts? The last belts I purchased were from Sears and were aluminum oxide and generally worked well.
I use the sander/grinder on lawnmower blades, brackets, etc. Thinking about zirconia belts vs aluminum oxide. Is it worth it to step up to zirconia?
This source has belts in the $3-4 each range and a nice selection of grits:
http://www.leevalley.com/US/wood/page.aspx?cat=1,43072&p=48040
This source only lists 36 grit but is cheap at $1.79 each
http://heleta.com/review/product/list/id/777/category/173/
This source has a reasonable grit selection with prices in $2.24-$3.16
http://www.mscdirect.com/browse/tn/?searchterm=1x42+zirconia&hdrsrh=true
Not sure what the above sources charge for shipping.
BillK
Beautiful Southern Maryland
Larry,
I buy 4 x 36 belts from MSC mainly because they carry Norton belts. I have found that the Norton ones outlast everything else that I have tried. Seems like this is a true case of "you get what you pay for" :)
exmaxima1
Midwest
Aluminum oxide is the cheapest and wears very quickly on steel. I tried some "ceramic" belts and they last far longer on harder materials like mower blades, plus they cut more aggressively with less heat buildup.
mopar440_6
Carlisle, PA
Norton, SAIT, or Merit Abrasives for brand. Amazon has a lot of SAIT belts in the $22-$25 per 10pack range.
Sent from my XT1058 using Tapatalk
tstaude
SE Wisconsin
when we are in a pinch at work, we sometimes take a 6" wide belt and rip with a straight edge and razor blade. If you find the belt you like, you can size it accordingly.
BTW, 3M cubitron if you want to hog off material rapidly.
metalmagpie
Seattle
Don't buy a lot of sanding belts. The glue joints fail after a few years just from sitting on the shelf.
Trugrit is a good source. Other knifemaker supply sites also sell belts; however, 2x72 is a much more common size than 1x42.
If you dig around and come up with the SKU for the old Harbor Freight 1x42 belt sander you can pull up its manual and find the SKU for the belts they sell for it. Then you may be able to order those belts from their parts network. I have had good luck with Chinese abrasives.
Aluminum oxide is a reasonable abrasive, but there are definitely newer and better ones.
The latest one is 3M Cubitron. Those belts are more expensive but last a LOT longer.
I used to own a 1x42 belt grinder and loved it. I sold it to a guy who still has it and loves it. They are damn handy around a shop.
metalmagpie
L
larry4406
Northern Virginia
Thanks Metalmagpie.
I was thinking on ordering 5-10 to have on hand since SOL at local hardware stores. Good point on degradation of glue from storage.
James-W
Southeastern Wisconsin
metalmagpie
I have used Harbor Freight belts in the past. They work quite well for wood, but not so good on metal. On metal they seem to wear down rather quickly.
Gizmosity
SW Wisconsin
I've used Klingspor for years and years, although for wood. They carry quite a few different types of belts in that size. I've never been dissapointed in the quality of their abrasives.
