2-2-2-4 vs 2-2-4-6 MHF
exranger06
CT
ard
No electrical supply houses around you?!?
FWIW- I will call and check pricing, very causal: "hey Bob, Dave here- trying to cheek pricing on XYZ", They may ask "who are you with again?" I use my biz name, which doenst have an account. I may say "ABC biz, no account with you".... But I try to get a price first. I have, on occasion, been surprised at the counter with one or two stores. Applies to all trades.
colomboj
Cornpatch USA
It's probably just fine to use the cable with the 2/2/4/6 if you have some 240v loads on it, but the age old adage of "better safe than sorry" comes to mind. I would try to source some 2/2/2/4 before I tried my luck with the inspector.
mm08822
2-2-4-6 is perfectly acceptable. A reduced neutral is very typical as it only carries the imbalance between legs. 240v loads typically do not use a neutral and all 120vac circuits are staggered across the legs - A-B-A-B..... So the load on a neutral is very low. You would have to try really hard to overload a neutral in a feeder.
I wouldn't spend too much time searching best price for 16-20'
Stuff
Why MHF? For 16' use SER or conduit end-to-end with THHN/THWN.
E
exranger06
CT
Can't use SER as it's going underground. I don't really feel like installing conduit the whole way either, so it's being direct buried.
pattenp
Virginia - USA
Just use the 2-2-4-6 and move on. Not worth the effort to find 2-2-2-4.
But if you have a local Lowe's. My local Lowe's carries 2-2-2-4 @ $1.49ft.
Falcon67
Merkel, TX
Or find another HD or Lowes - should be common. Is around here, but we also have lots of mobile homes around here too.
>Wire and cable your way will cut to the foot and 2-2-2-4 is $1.17ft.
Which is about .40 cheaper than what I paid at HD for 2-2-2-4 back in 2011. Nice.
Crazyjake8493
Upstate NY
The 2-2-4-6 should be fine, but every Lowes I've ever been to has had 2-2-2-4, if you have one nearby. Other than that, a supply house should carry it, but may cost more than the big box stores.
terabitdan
Wireandcableyourway shipped me 2-2-4-6 when I ordered 2-2-2-4. They caught their own mistake and called to ask if it would be an issue. Rather than dealing with the returns I asked my inspector who immediately approved it.
