2 bulb or 4 bulb?
illmatyk
Yigo, Guam
I am going to convert my lights in the garage/carport into florescent bulb fixture. What do you guys recommend for this, a 2 or a 4 bulb fixture? Also, what type of bulb( T8 etc )? Sorry, very very NOOB at this...
Thanks.
:beer:
gatchel
West of King of Prussia, PA
It really depends on what you are trying to accomplish as far a light levels are concerned and the areas you are trying to illuminate. T8's are probably your best bet.
1BADLS1tuner
Nebraska
i vote 4' 2 bulb t8 fixures.... you can place more lights in more locations, this will keep you from having so many shadows and more even light, jmo...
Thats what i will be using in my 32x48x12
ddawg16
S. California
I also concure with the 4' T8....
One other thing....task lighting....I'm becoming a big fan to the T5 bulbs....fit in lots of small places.....they put the light where you need it....
So...do your general overhead lights with T8's....but consider some T5's in the task areas....especially under cabinets....
jvitez
Big Sky Country, Canada
In my locale, 2 bulb T8 fixture at big box stores are about $22 each, whereas 4 bulb T8 fixtures are $55-60 each. Go figure. Check out prices in your area. I like even light, so my preference is for more 2 bulb fixtures in a continuous row than less 4 bulb ones. That assumes you can get the light level you want with 2 bub fixtures.
TireTracks
Yakima,Washington.
In my dads shop, there are 3 8ft twin tube fixtures ( dont know anything about them), 3 100w incan's, and then I have a 4ft 2 tube light hanging off the upper shelf of my bench, very nice and bright.
I would try and have light evenly Iluminateing all of your machines/work tables/benches.
I
illmatyk
Yigo, Guam
Thanks for the inputs guys:thumbup:. Well, after checking HD and another local Home Center here, I found the fixture I want( $33.99 ). It accepts both T8 and T12 bulbs. Only problem, the guy that was helping didn't seem so sure on which bulbs were T8 and T12:wtf:
So tomorrow morning( since I'm off ), I'll be going back for the fixture and getting the bulbs at HD.
I'll be looking into the T5's ( as ddawg suggested ) for my workbench and other areas.:thumbup:
:beer:
MrMark
Southern Cal.
T5's are for highbays, not workbenches. You'd be better off with some bulbs on a desk light for a workbench. Less eye strain.
djjsr
In the cornfields
The numbers are the diameter of the bulb in eighths of an inch. The T8 is 8/8" (1") and the T12 is 12/8" (1 1/2").
HIRISC
Minneapolis, MN
2 bulb T8's FTW :)
cderalow
Potomac, MD
Personally, I'd go for T5, more light output with lower energy use. More expensive initial cost, but lifetime use cost is lower.
pattenp
Virginia - USA
Was this stated on the box or was the same guy telling you this who didn't know the difference between T8 and T12 tubes? Usually a T12 tube will not fit a T8 fixture because the tombstone sockets are too short. But a T8 will fit in a T12 fixture. Not that you would want to do that.
cderalow
Potomac, MD
Some fixtures are designed to accept both. what it winds up being is the T12 tombstones, with a ballast that is capable of powering T12 or T8 bulbs.
I
illmatyk
Yigo, Guam
Thanks for the info:thumbup:
It was stated on the box.
Norcal
2 bulb T8's FTW :)
If anyone in the Sacramento area wants 1X4 recessed FL fixtures, the Roseville Habitat for Humanity ReStore has some new 277V Cooper models for $10 ea, replace the ballasts & it's still cheap....
