pixelmonkey
It's Not yet complete.
Few issues with the house that need to be fixed before I do much more to the garage, but for the main construction, it's finished. Some more painting and cabinet door adjustments and I will be happy.
the next version will be built better... might start that in spring. *looking at a new house with larger yard and larger garage*
CONSTRUCTION NOTES:
- frame is 2x4 pine lumber
- sides and face plates are 1/2" plywood
- shelves are 5/8" particle board for top shelves and 3/4" for lower shelves
- paint is oil based enamel from lowes.
- shelving rubber is from lowes. *label shows it to be used under a tread mill. i think it was a 4'x8' roll for $40
- legs are brushed aluminum, adjustable. online search should help.
- the "closet" cabinet next to the garage clears by 1/2"
- entire cabinet system is screwed to the wall and doesnt require legs or floor support, but I added them for safety to the lower cabinets.
- "closet" will support me at 250lbs
- counter top is 3/4" plywood. 4'x8' sheet was cut into 2'x8' and glued together and screwed from each side using 1 1/8" sheet rock screws
- metal secured to counter top
- metal with counter top screwed to frame
the overhang near the tool boxes will be used for a vice. holes will be drilled through the metal and wood to hold it in place.
MORE PAINT will be added. white on edges and backs of doors not yet painted. then a few more additions to the doors will come over winter.
more to come!
chris<pixelmonkey>
CONSTRUCTION NOTES:
more to come!
chris<pixelmonkey>
