I'm having issues with my septic system's pump (pump's in a holding tank). The pump trips the breaker all the time. The pump is new and functions fine when powered by an extension cord on a different circuit, so a problem within the pump has been eliminated. It's my belief that there is a short in the underground wire (direct bury) due to a rotor tiller incident a few years back.
I'd like to redo this circuit with conduit (PVC scd40) and THHN. The current set-up has an overflow/high effluent alarm box outside the holding tank. There are 2 circuits running to this one box. It's not a shared neutral circuit. Two separate circuits via 12/2 w/g UF, two separate neutrals. One powers the overflow alarm, one powers the pump. I believe this to be a common set-up and it was professionally installed by licensed electrician.
Here's my questions: Can I run ONE conduit and put both circuits (4 THWN wires + ground) through that one conduit? Normally I say that's not right, but there are already two circuits running to one box anyway.
If that's not allowed with THWN, can I do it with UF and simply use one conduit for protection purposes?
Please give me your thoughts on this situation, Thanks!
