2 doors, same height or
prostock3
walled lake
so im building a big garage on my house in walled lake. I would like to have a hoist inside and higher ceilings.
My question since i live in a neighborhood should i do a 16x8 door, along with a 9x8 or should i do a 16x8 with a 9x10. Would the different door height look silly?
tomshep
9x10. The difference is minimal and it will give it character from the street.
Tom
nolimits76
Oklahoma
I'm not familiar with the area, but are there any restrictions on what type/size of structure you can build and how it must look? If so, review carefully as this may dictate the direction you go.
Leaflessshadetree
Don't ask.
Two different heights is common around here usually the taller door is 12' or more.
Depending on the style/size of the building and the positioning of the doors it can look strange. For a 2' difference I'd consider going with 10' on each, for a lift I'd go to 12' tall.
I would definitely go wider than 9' on the shop door. Mine are 10' and I should have gone 12'.
volleyball
NY, not NYC
How about a 16 x 12? how many doors do you need? Maybe a door on the back side.
If I were going for 3 doors on the front in a neighborhood with a big door, I'd design it so that the facade was broken up and it looked almost like an addition. Having a normal height and a tall door on a straight facade looks tacky.
kbs2244
I have to disagree.
Having a common horizontal top line for windows and doors is a long standing building design standard.
Try and find someone that can run the design software that allows you to input a digital PIC and then add to the PIC with various additions, colors, etc.
It will let you play with all kinds of “looks.”
finn
The UP, God's country
Try adding some archetectural features to build on the fact that the doors are a different size, ie stone facing, stepped front wall (recessed or protruding), roof features, etc.
bczygan
DETROIT! Arsenal of Scrappers
We're going to need to see some photos...
I designed a house on the south side of Walled Lake, where the two stalls of the 2 car garage needed to be staggered, so the turn into the garage would work, making the use of two doors necessary.
As mentioned above, if the 2 spaces are different heights or sizes to begin with, then that will reflect on the exterior roof line or walls, so the different sized doors will look appropriate for the masses of their respective stalls.
The rule about multiples of something. If they can't match, make them obviously different. If they are just a little off, it will look like a mistake.
AndyL
Vancouver
Depends on design...
And your installer to some extent - I did one recently where we used ranch panels (and glass) for the bottom 5 - then used a flush panel on the top of the taller door - did an amazing job of hiding the fact that the other door was a different height. Because that extra panel was closer to the stucco - it really looked like they matched.
ez-duzit
Marina del Rey
Make some copies of the front elevation so you can sketch different approaches. But why would you need a door opening higher than 8'? Do you own a tall camper or?
Nevertheless, make both doors the same height.
volleyball
NY, not NYC
Universal design homes have taller doors on them for the vans the occupants will likely be going in.
As the 8' ceilings become less common than taller ceilings, taller garage doors will become the norm.
