2 drill odd bits...2 questions
1982fxr
Phoenix
What took a shank fit like that first one?
What is the second one for?
timgunn1962
Lancashire, England
The first one is for use with a Brace. Old school: turned by hand.
The second is for drilling holes then rotary-filing them into slots, etc. It looks way past its best.
The Brace has been rendered largely obsolete by cordless power tools.
The drill-and-file jobbie was never good, IME. It had a place in my site box as the least-poor available way to deal with some unforseen problems. If the problems were forseen, I'd take a better solution, usually a router or die grinder.
dutchgray
Dorset. England.
The only time I use a brace nowadays is if you have to drill right in a corner or against a wall and can't drill at an angle, as using a ratchet brace you can get in closer than any drill. This is a once every few years occurrence. Last time was to let in a curtain pole into an oak beam a little so that the curtain would go over enough when open to not block some of the window.
Lwel9226
So Oregon
I think the second one is for rotary file as mentioned but mainly for dry-wall/sheetrock, hence the very small "teeth" on the
file part....
LynnW
