I received a call from a customer. An HVAC job I did failed inspection for 2 issues. The first issue, apparently on the 240V feed to the A/C unit in the panel there is an aluminum ground wire junction-ed to a copper wire with a standard wire nut. The panel was just installed, so I called the electrician who installed it. He told me 1) the standard wire nut is fine because it's not a current carrying conductor. 2) The job passed inspection so it's my problem.
So thats the first question, can an aluminum ground be connected to a copper ground with a standard wire nut as opposed to a purple wire nut for this purpose?
The second issue, there's a service disconnect for the A/C unit on the outside wall. Theres a 6' seal tight whip coming out of the disconnect, it's strapped within 6" of the disconnect. The other end obviously connects to the A/C unit. In between I neatly connected the whip to the refrigerant piping because it looks neater and isn't flopping in the wind.
It failed for "Support liquid tight at condenser independently." Which I can only assume means he wants it loose from the refrigerant piping. Ive done it and seen it done like this 1000's of times without issue.
My second question, is there something in the NEC that would make what I did incorrect?
Thanks.
Thanks.
