loosegoosegarage
- Joined
- Apr 30, 2026
- Messages
- 12
30x50 slab was just poured with 12" deep digouts for 2 post lift.
They were going to do 1 control joint long way (50') and 4 across (every 10' from front to back) which would have ended in 10' x 15' foot sections.
They ended up switching to 2 joints front to back, still 4 across to create 10' x 10' sections, which I do prefer.
However, I had them skip the 10' section that would run in between the 2 lift columns, as I swore I had read that you did not want a seam in between them.
Now I am second guessing that since it is 10' x 20' which is larger than recommended and I don't want to risk it cracking.
Is it safe to cut a control joint in between 2 post lift columns? Not under the base plates, think of down the middle where you would pull a car into lift.
