2 post lift battery jig
70runner
Avocado country
Now that I'm well into the golden years, I've discovered DIY replacing standard Group 26/27 batteries (~30/50lbs) is a lower back wakeup call. Even worse Odyssey Group 27 batteries (we use in our older mopars) weigh nearly 70lbs. There's all manner of lifting tools which don't appear to reduce the lower back strain.
One solution, offered by the wife, why don't you use your tractor (with forklift attachment)? Well, hon, that's a great idea, but I'd be a little nervous maneuvering the tractor in close proximity to our vehicles.
Put the thinking cap on, can I fab a jig that uses hydraulics (2 post lift) to replace my lower back muscles? Penciled up a simple post-telescopic arm-hooks concept. For the post base used an extra 6" lift pad extender. The upper, circular portion of the extender nearly fit inside some scrap 2x2 steel square tube for jig post. Nearly, because I had to mill .05" off each side of the extender which provided a flat contact surface for welding. For the lift arm, used some telescopic, perforated steel square tubing leftover from another project. Bolted a shorter perforated cross piece to the telescopic arm end so the cross piece can be rotated +-45deg if necessary. All that was needed was a couple threaded hooks on the cross piece for the battery handles. Some cutting and welding, presto a $7 (cost of the 2 hooks) 2 post lift battery jig. Couple pix of mockup with RAM 1500 to size the lift arm, then painted.
70runner
Avocado country
That was one option I considered. I just wouldn't be comfy with this holding a 70lbs battery across the fender/grille of our mopars (70 Roadrunner and 69 Charger RT). Much more comfy with direct engagement of the lifting handle. For batteries without handles, will use a couple 500lbs lifting straps.
gorilla
that would be a good idea to adapt to a floor jack or a transmission jack if you don't have enough room around your lift to get a car close.
aka Larry
Eastern, NC
Very smart! No need to strain your back when you have a tool right there ready to be adapted to do the job.
I've used mine for purposes other than lifting vehicles as well. Around this time last year I bought a very heavy cast iron wood stove. It was sitting on a trailer when I bought it so I was able to easily roll it from that trailer onto mine. When I got it home I backed my trailer between the arms and looped a pair of lifting straps over the arms to lift the stove just a few inches. I then pulled the trailer from underneath, lowered the stove onto the shop floor, and rolled it into place. No strain on my back!
new_wood_stove_lift-jpg.2253071
