2 post lift column plumbing
JohnnyK8
Illinois
Can't get much closer than that!
Do you have a car on it?
Sent from my SM-A505U using Tapatalk
C
CJseven
Southeast Missouri
No I haven’t hooked the power pack up yet, I have some 1/16 shims under the high side it seemed to need them before I started to tighten down the anchors. I’ll go back out in a bit and remove them and see what that does.
Kaizen
New England
If that’s a two foot level it needs to be shimmed. You will be below this thing. Make it perfect
JohnnyK8
Illinois
Here's mine with a 4 foot level.
C
CJseven
Southeast Missouri
I moved shims around and have it much closer , I only had a few 1/16th shims that were under it when I removed the lift from the old shop. I’ll have to get make some temporary shims today and see how that goes. Once I figure the shim thickness I’ll make permanent ones out of aluminum plate I have.
C
CJseven
Southeast Missouri
Tried the plumb bob off the top of the column the front to back is off 7/16 from the top to the bottom of the 14’ column. So I’ll have to make more shims befor3 I can go any farther.
brownbagg
what i did on mine was shim it perfect then tilted the post back and slap some non shrink grout under it, then bolted it down. the excess grout would squeeze out and i have full bearing once it set up, but it still setting on the shims.
C
CJseven
Southeast Missouri
Made shims yesterday out of a few different thickness of aluminum plate and was able to get the columns pretty much dead on. Didn’t take much at all most were only 1/16 off. All that’s left is hook up power and bleed the hydraulics and adjust the cables.
brownbagg
on the grout, i just got what the box store had on the shelf, its all just basically the same
Wangstang
Triangle Area, NC, USA
Are you all just using flat stock to make your shims?
I saw someone mentioned aluminum above but it seems like steel would be preferred. Am I overlooking something?
Happen to have any photos of your shims you can post?
Kaizen
New England
Mine had galvanized washers. Nothing fancy required
C
CJseven
Southeast Missouri
I just took some 6061 aluminum plate of different thicknesses and cut some 3” squares, drilled 3/4 holes in the center then used a band saw to notch one side so I could slide it around the anchor bolt. The factory kits all use plastic shims.
iowa4x4dieselman
I would use a shim kit designed for bolts. I would bet this would be safer and easier to get perfect than grout.
