sjvicker
I've installed several jib cranes and in every situation the epoxy was specified over the wedge anchors. I know the "cone" of pullout is the same but after using it and wedge anchors, I definitely trust it more than a wedge anchor. It's likely not used as a standard for 2 post lifts because its more expensive and requires more prep as the holes must be completely clean of dust before setting the epoxy.I assume the Hilti epoxy is superiors to just a Hilti anchor (without epoxy)? Can anyone confirm? I assume challenger doesn't use this as their "standard" install procedure due to the cost of the epoxy?
I think you're going to have to come to terms with the fact you'll have vacated holes or cut fasteners in your slab when this is all said and done.
