samert111
One of the cylinders on my Forward DP97 two post lift is leaking at the lower gland seal where the rod exits the cylinder. It's the cylinder opposite the pump and controls. I have the seal kit for the cylinder and want to remove it to rebuild it.
If I raise both carriages normally to the top so the rod is up inside the cylinder, then remove the 2 nuts where the rod connects to the carriage, can I just lower both carriages normally to clear the carriage from the disconnected cylinder, while relying on the equalizing cables to support the weight of the disconnected carriage until I can apply the carriage stops to relieve the hydraulic pressure so I can disconnect the hydraulic lines and remove the cylinder?
