2 post lifts,info,opinions,etc...
mrobins297aaa
south east michigan
also there pretty fast on the shipping, I had mine in less than a week to the conway terminal.
One more thing if your picking it up at the terminal make sure your prepared to deal with the way they ship them with the raised angle iron frames on each end.
I wasn't prepared for that even though I brought everything but the kitchen sink.
I new the lift would over hang my trailer but I wasn't prepared for the frames on each end, lucky the guy at conway gave me a couple of pallets.
financer83rs
This is the lift i purchased in April 2009. I have used it hundreds of times and have not regretted it for a second. The whole family loves me know. I paid delieved to a terminal 90 minutes from home $1633. My brother is an ASE cert tech and he appreciates it and he has experiance with dozens if not hundereds of lifts.
TP9KAC Car Lift
These lifts have the heavy-duty leaf chain, steel pulleys, high-strength
cable equalization system and everything you’d expect from a quality lift.
Features:
9,000 lb lifting capacity
Asymmetric design
Dual cylinders with low friction chain rollers
Low profile automatic arm restraints
Stackable drop-in height adapters
Free mounting hardware
Powder-coated paint finish
Electric override automatic safety shut-off
Specifications:
Model Number TP9KAC
Capacity 9,000 lbs
Lifting speed 50 seconds
Motor rating 2HP 220V 30A
Width overall 134"
Height overall 142"
Lifting height 70.5"
Lifting height(with ext.) 75.5"
Low pad height 4.5"
Width between columns 109"
Drive thru 92"
Shipping weight 1500 lbs
financer83rs
As far as the clearance issue I had the same so I added a bay to my attached garage. If i think of it i will take some pics to night and post it. It isn't beautiful but when you consider what the goal was it looks good and blends fairly well. My girlfriend doesn't appreciate it but the rest of the family does. Hopefully pics tomorrow.
financer83rs
Here are the pics. Some kinda **** but i tried. if there are any questions fire away. The first three are of my unattached garage prior to siding. The other is the attached garage that i added a bay so i could accomodate a lift.
racerock
Can you tell me who they are? If a road trip to Texas would save a lot of shipping cost, The price might not be even as much as you mentioned in the end.
Mike
Trust me, your road trip will cost you more than LTL Freight to your local Terminal.
Not only that, but many companies must also charge you TAX when you pick it up -
- tax on your gas
- tax on your tolls
- tax on the product
= more dinero than supporting the truck drivers...
3x9RT/SE
Been using mine alot lately,BP xpr-9fs,it is awesome having a lift!!!!!!
bad94sup
Thornton, PA
Nice! Any other comments with respect to your particular lift? What cars do yo use it on? How is the clearance around the doors. I'm considering the same lift! :thumbup:
