So my second floor hvac system has ceiling vents and a ceiling return. Because of this in the winter while the heat is running it's like 25 degrees warmer at the ceiling than the floor. Which also means the heater is sucking in very warm air.
I need to turn all my ceiling fans on which is a pain.
I'm adding a closet which just so happens to be right next to the ceiling return vent. I'd like to somehow build another return that pulls air from down low. I'd also like it to be switchable so I can use the ceiling return in the summer and the low return for winter.
Not sure how this is done.
My current return duct work in the attic is insulated flex duct if I had to guess it's 12-14" wide. There's a grate in the ceiling and the filter is located inside the grate.
8ft ceilings if relevant.
Do they make some sort of Y splitter for thick duct?
