break out the torches and a sawzall, get a 2 spd. diff. out of a truck and install it in the 1/2 ton.
This why Ford is going 6 speeds on all of their F-Series.
But, it is difficult to believe that a Ford 6 speed ****** will work any better than anything else Ford has ever built. The OP wants something he can drive, not have DOA in the yard.
If the truck is a 4X4, you will need to have the Gear Vendor (or other splitter) before the transfer case, otherwise, when in 4 wheel drive, the truck will try to tear itself apart (similar to having 3.08's in the front and 4.56's in the rear).
Anyway, the old Lincolns from the 40's had a Columbia 2 speed rear if I remember correctly. And a number of cars from the 50's had an overdrive transmission, with a lever or knob to control it.
The B-W overdrives were used up into the 1960s. . . . . When in overdrive mode, they only freewheel in the 0-30 MPH range. When actually in overdrive above 30 MPH, they are in lockup mode. The only time it is a problem is if one were coming down a steep, slow mountain road and the speed dropped below 30 MPH, then the overdrive would disengage and go into freewheel.The 50's car OD units are the Borg Warner type and fit on the tailshaft of the trans. They also freewheel in OD when you let off the gas,
FWIW, the B-W overdrives have been used as the basis for a number of aftermarket overdrives including the Hone-O-Drive and one for a T10 4-speed by Tom Beatty. Given the OPs original question, it is not something he will be attemptingI am not aware of how you could adapt them to a modern trans.
semi off topic question. Does the gear vendors unit only work on manuel transmissions ? Does the gear vendors unit bolt right up to the transmission, and then you just shorten the drive line ?
