djjsr
Question for you hvac guys.
I have a 2 stage A/C system that needs a new thermostat. The old thermostat has 4 connections being used as follows:
Terminal Rc - red wire
Terminal G - green wire
Terminal Y1 - blue wire
Terminal Y2 - white wire
My problem is that I can't find a thermostat (locally) that has a Y2 connection for the secondary cooling. So, to keep the A/C running, I used a simple digital thermostat and just connected the blue wire to the Y terminal.
Without the white wire connected, obviously the second compressor doesn't run and only one compressor isn't doing the job.
Can I connect both the white and blue wires to the Y terminal on the new thermostat to get both units running until I find a proper thermostat?
Thanks in advance if you can advise.
