TXNinAZ
Hi all, I've got a tech coming in tomorrow/Tuesday to install a 2 ton mini split cooling only system in my garage, and I'm hoping for some input on what to watch for and to make sure he does it right.
It may cost me a few more dollars, but I'm going to ask that he run the line inside the wall, rather than a channel on the side of the house (HOA is a real PITA and I don't want to redo this because of something that stupid).
Should I have a separate terminal box on the exterior wall, no matter what? The unit will only be about 15 feet from the exterior-mounted 200 amp panel, but I'm guessing he should put up a terminal box anyway.
Can I put some kind of meter at the new condenser to monitor how much power it draws? I'd like to have an idea what impact it will have vs prior years' energy usage, but because I added a bunch of insulation last winter, it won't be as simple as just comparing previous bills. Thoughts?
I plan on keeping the unit running to maintain about 88* maximum and then lower it to 80* when I want to work out there. With no climate control, it generally reaches the low hundreds in July/August during the day, and not much below that at night.
I've researched before, but not fully happy with what I've found. The vinyl sweeps on the edges of the doors (one door is 16x8, the other 8x8) are pretty dry and stiff at this point, and leave me with a light gap around the doors that needs to be fixed so I don't try to cool Arizona. Any superior products I haven't seen yet?
Thanks, everyone- this is definitely the most helpful forum online!
