2 vs 1 stage compressor
Hello I’m looking at buying a new compressor. I have found a cheap 2 stage but it has less cfm than a 1 stage about the same cost. I use compressor for tires, grinding, and plan to get a plasma cutter, vapor honing machine and a paint gun soon. Am I missing something here, or will the cheaper 1 stage work better for high demand tools???
https://www.aircompressorsdirect.co...2100-Air-Compressor/p102441.html?new_bottom=1
https://www.aircompressorsdirect.co...T6195-Air-Compressor/p67257.html?new_bottom=1
Don1357
Palmer, AK
Higher CFM wins. Any air intensive application will eat through the air reserve in a hurry so you are left to whatever the pump can deliver, measured in CFM.
Also make sure that the motor is rated for 100% duty cycle.
these looks better:
https://www.aircompressorsdirect.com/Ingersoll-Rand-SS3L3-Air-Compressor/p688.html?new_bottom=1
https://www.aircompressorsdirect.com/Eagle-C4160V1-Air-Compressor/p5515.html?new_bottom=1
https://www.aircompressorsdirect.com/Puma-PK6560V-Air-Compressor/p592.html?new_bottom=1
X
these looks better:
Thank you that was my thoughts too. So why are these 2 stages more expensive lol
1Garageman
Columbus, Ohio
MacMcMacmac
canada
Staging allows more efficient running at higher discharge pressures. If you are staying below 130psi or so a single stage compressor is a better bet.
