Tscott
Alright guys, I have a bit of a snafu. Part of the plan while running conduit to the new shop was to redo a few little things on the property that needed to be done. One of these issues was to feed the existing well from the house instead of the meter on a pole barn that is going to be removed. I also wanted to run a line from the well to the fence to power a gate opener. I must have shut my brain off when I came up with this one because the service to the well is 220V and the outlet at the gate needs to be 120V. The house has an outlet box outside that is going to be used for the well. This box has 2 wire (1 black hot, 1 white hot, and a green ground) 220V to it. This will feed the well fine, but then how do I take only 120V to the fence without a third wire (neutral)?
I could just run 3 wires from the well to the fence, and connect the neutral to ground at the well, but I am pretty sure that is not acceptable to the code. Any thoughts?
Also, there is really no was to get a neutral wire to the well from the main panel. I would rather get a second battery for the gate and add another solar cell.
Tom
Tom
