2 yr old dehumidifier dead ?
FleaDog
Hi guys I bought a brand new GE dehumidifier for my basement 2 yrs ago. its worked well. temps are around 60-65 degees down there year round. it works on off all day and keeps humid around 50%. recently it has started making all sorts of cracking noise and does not appear to be condensing as much water and humidity is a little higher. is it dead?
jjjrmx5
Cincinnati, OH
I doubt it.
I have one that is a decades old and just keep buying parts for it when needed. :)
Assuming it is a stand alone and not connected to your HVAC system, do you direct drain it via a hose or use the bucket system?
The "bucket full" contact switch can short out or the humididy probe sensor can sometimes go bad.
If overused the compressor can fail but I see that only when the intake fins are not cleaned regualary of dust and debris.
May be a bad humidity dial if you turn up and down a lot but "cracking" is not a noise I hear a lot out of a de-humidifier. Even a bad one.
If not mechanical in the bucket catching system or it's overflow switch, it sounds electrical. Which means a short or bad component.
Also keep in mind de-humids can freeze up/ice up just like your car's a/c system if too cold or in strange conditions. BTDT. Gotta let it thaw and then good to go.
Sounds like you need to dig further. :thumbup:
Got a model no. for your dehumidifer so we know what you are talking about?
kbs2244
Like he said, they are pretty simple machines and not hard to trouble shoot.
The compressor is the same as in a refrigerator and just as trouble free.
You have some micro switches that may corrode and a fan that may need a little oil, but that is about it.
Your noise may be a switch trying to make or break, or the fan blades hitting something.
pop pop
Virginia
Cracking is likely ice warming and ice should not be present. Likely you are low on refergerant. Usually not worth repairing.
Super Sport
West Michigan
Newer dehumidifiers are not reliable at all. Read reviews on some, most are terrible saying they didn't last long.
I bought two used, and within a short time they started icing up on the back. I recently got a killer deal on a new one, but haven't unpacked it yet. I bought the extended warranty with the plan on needing it.
F
FleaDog
so I bought it at Walmart with a 3 yr warranty. they sent a appliance repair guy out to look at it. said has a contaminated coil. needs replacing.
